Re: DIY clean chamber, v2
February 7th, 2021, 18:17
DeVlL wrote:Hi LarrySabo
I was just going to ask you to measure air particles with a meter. It looks great, I will try to replicate its cabin in aluminum instead of wood. Does the HEPA 14 filter come in various sizes? Do you also have pre-filters before you get to the HEPA filter?
regards
Thanks for the kind comment. The HEPA filter I used was available from a local hardware store and they didn't have many choices. For the V2.1 version of the chamber, I used a larger filter with higher filtration ability (BlueAir 200 series, 18 x 14 x 1.8 inches, 99.97% @ 0.1 microns). I did incorporate a pre-filter (Hammock filter - Duststop Ultimate) which as shown in the pictures for which I provided the link above, under other stuff, but it's pretty transparent (even folded over several times as it was) so a better pre-filter would definitely be an improvement.
If I were to start over, I'd make it longer; with all the head comb storage boxes piled up along the left edge, and miscellaneous tools in a parts tray and pouch on the side-wall at the right side, there's not a lot of spare room. Two of the BlueAir 200 filters end-to-end would make it 36" wide and you could add a few inches on each side to make it 40" internally, which would be more comfortable. I'd also make it about 6" deeper.
Good luck with your project and please do share your results!
Larry
February 8th, 2021, 15:20
regards
Larry
Thanks for your information.
My idea is to make it in aluminum instead of wood. Put interchangeable pre-filters and HEPA 14 filter. Also led lights and some more details. Your cabin is wonderful, I was looking for something similar for me.
Don't worry I'll put the previews in this thread.
I forgot to ask. What model of motor does it have internally to move the air?
Greetings and thanks
February 8th, 2021, 21:20
DeVlL wrote:
LarrySabo wrote:
DeVlL wrote:Thanks for your information.
I'm looking forward to see your completed project! The motor I used was a CircuitTest CFA11515055HB (115v, 150mm, 231CFM).
February 10th, 2021, 10:59
Hello
I'm interested in your conversation about cleanroom manufacturing.
I have a small question about the engine.
What is its power, do you have a reference?
Do you have pictures with the engine in place and other pictures with more details?
Thank you
February 10th, 2021, 12:25
Hello @angoul. If "engine" means the fan motor, the full specs are in the site to which I provided a link in the post immediately above yours. I provided pictures, parts list, airflow video, plywood layout, etc. in the HDDGuru files section, i.e., here: http://files.hddguru.com/download/Other ... mber%20V2/
Let me know if there is anything else you would like to know.
Larry
angoul wrote:Hello
Thank you
February 10th, 2021, 13:32
Thank you for your answer
I've taken a good look at your photos, video and your file
But I don't understand how the air is propelled in relation to the filter. I think there is an engine, but I can't find it on your file. I just find the fan.
As I'm in France, it's not easy to find the equivalence in France of the spare parts.
Thanks again for your support
February 10th, 2021, 14:04
angoul, I guess I'm not understanding what you mean by "engine." If you mean motor that drives the fan, the answer is -- it is built into the fan. The fan is no doubt made in China like everything else these days, so I would be very surprised if there is not a version compatible with your electrical system (220v?). In the worst case, look for a fan with the ability to deliver good air flow under high static pressure. You can always mount it atop the clean chamber, on the outside. Many DIY clean chamber/laminar flow bench projects utilize a squirrel-cage fan-motor assembly like you might find in a small furnace or air conditioner. If you tell me the specs of your electrical system, I may be able to help find a suitable fan.
Larry
angoul wrote:Thank you for your answer
February 10th, 2021, 14:27
I'll stick with your plan and proposal since it works very well, why go elsewhere
Now back to work, but it won't happen right away.
February 11th, 2021, 7:09
LarrySabo wrote:angoul, I guess I'm not understanding what you mean by "engine." If you mean motor that drives the fan, the answer is -- it is built into the fan. The fan is no doubt made in China like everything else these days, so I would be very surprised if there is not a version compatible with your electrical system (220v?). In the worst case, look for a fan with the ability to deliver good air flow under high static pressure. You can always mount it atop the clean chamber, on the outside. Many DIY clean chamber/laminar flow bench projects utilize a squirrel-cage fan-motor assembly like you might find in a small furnace or air conditioner. If you tell me the specs of your electrical system, I may be able to help find a suitable fan.
Larry
Thank you very much LarrySabo.
The model you put the fan also has a 230v version
Here the link of the page.
https://www.circuittest.com/cfa23015055 ... m-fan.html
I am also thinking of integrating a green telescopic light into the cabin and even the sub-lift disc extractor with its vacuum pump and foot switch.
Thank you very much for your help.
February 11th, 2021, 9:39
That's great, deVIL! Be sure to show us your completed project. I'm pleased if my information helped. Thanks for the link to the 230c 50/60Hz version of that fan. It should be perfect for use in France.
Cheers, Larry
February 12th, 2021, 7:52
LarrySabo wrote:That's great, deVIL! Be sure to show us your completed project. I'm pleased if my information helped. Thanks for the link to the 230c 50/60Hz version of that fan. It should be perfect for use in France.
Cheers, Larry
I saw it on the web, that it had a 220v version. I am from Spain and here the voltage is 220v.
I am also looking at the hepa h14 filter, and I have found this page.
https://www.venfilter.es/producto/laminarven-66-mm
It comes in various sizes. I have to ask prices from that provider.
March 24th, 2021, 4:48
Hello
Have you made any progress on your project, I am currently on hold and still looking for information
Sincerely
March 25th, 2021, 5:13
angoul wrote:Hello
Sincerely
Hello.
Are you asking me or LarrySabo?
March 25th, 2021, 12:36
To both of you, but especially to you Devil.
Thank you
March 26th, 2021, 10:07
"Have you made any progress on your project, I am currently on hold and still looking for information"
I've said many times that it has been working very well since I built it. No further modifications are required for my use, although I would built it bigger if I were to start over. Exactly what information are you looking for that hasn't already been provided?
Larry
angoul wrote:To both of you, but especially to you Devil.
Thank you
March 26th, 2021, 15:10
I just wanted to know if you had modified it to improve it
Again, thank you for your photos and plan that you shared
March 26th, 2021, 15:16
angoul wrote:I just wanted to know if you had modified it to improve it
I did build a V2.1 version that is deeper but narrower, but the only improvements were to use a higher efficiency filter and to put sealed foam weatherstripping between the lid and the body. Otherwise, they were identical.
March 26th, 2021, 15:46
Here is a cheap laser particle counter:
https://goughlui.com/2021/03/14/review-teardown-plantower-pms5003-laser-particulate-monitor-sensor/
A Sensirion SPS30 isn't that much more expensive:
https://www.sensirion.com/fileadmin/user_upload/customers/sensirion/Dokumente/9.6_Particulate_Matter/Datasheets/Sensirion_PM_Sensors_Datasheet_SPS30.pdf
https://www.digikey.com.au/product-detail/en/sensirion-ag/SPS30/1649-1106-ND/9598990
March 28th, 2021, 11:26
I Laminar flow benches are prohibitively expensive (at least for me). This reduces the cost by more than 90%, with verified air quality to boot. I love it! Thanks, Larry (and everyone else for new ideas and 220V parts list)!
March 29th, 2021, 8:47
Thanks @drun!
