 Post subject: Loader for WD10SPZX-22Z10T1
PostPosted: April 7th, 2021, 5:18
Hello everybody,
does anybody have a loader for WD10SPZX-22Z10T1 - Firmware Version is 0005008J.
Thank you very much.
 Post subject: Re: Loader for WD10SPZX-22Z10T1
PostPosted: April 7th, 2021, 9:09
I just found a possible one at http://files.hddguru.com/download/PC-30 ... ty/Palmer/
I will try it.
PostPosted: April 7th, 2021, 9:32
Very strange. I tried a loader from same firmware version 0005008J that i found at http://files.hddguru.com/download/PC-30 ... ty/Palmer/ but when I try to upload loader PC3K says: VCS ERR OFF TOO LARGE.
Is this possible? Same Fimware Version, but different loader?
PostPosted: April 7th, 2021, 10:25
Here you are
Mikippp
05.8JD.zip [743.07 KiB]
Downloaded 501 times
PostPosted: April 7th, 2021, 11:31
Thank you very much. Unfortunatly it says: VSC ERR OFF TOO LARGE.
But I found one in http://files.hddguru.com/download/PC-30 ... ty/Palmer/
"WDC WD10SPZX-00Z10T0-01-01A01-WD-WXH1A88A10X9.rar
WD10SPZX-00Z10T0 - ROM F/W version: 00050006"
This one worked fine. Unfortunatly HDD won't get good access to SA.
I can do a Head Test and it works fine with no errors, but I can't read the modules... Does this make any sense?
Any Idea about this case?
PostPosted: April 9th, 2021, 1:48
Stupid question, but I assume you're using a special "unlocked" PCB?
PostPosted: April 9th, 2021, 12:45
Yes, I use an unlocked PCB.
PostPosted: April 9th, 2021, 13:00
Have you checked if its the original ROM?
You can do this by checking the WWN number.
PostPosted: April 23rd, 2021, 8:17
Yes it's Original ROM. I got a Loader that's working fine, but I can't upload module 01.
After making upload of loader, when ein try to go into techno mode I get the following:
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 2
Cyl Count............................... : 512
Zone allocation table................... : HDDs RAM reading error Device Error Detected: "SCT INVALID FUNCTION CODE"
ROM:
Read ROM................................ : Ok
ROM Data size........................... : 1024 Kb
Flash ROM dir reading................... : Ok (Active)
Flash ROM dir reading (Ext)............. : Ok
Modules directory address............... : 0
SA regions address (RAM)................ : by default
Module 02 access........................ : Granted
SA Translator loading................... : No S/A SPT info avalable
ROM Modules:
ROM version............................. : 05.06B
ROM F/W version......................... : 0005008J
Overlay F/W version..................... : 05.07B
Servo F/W version....................... : 03.64
Heads configuration..................... : by map
Heads number in use..................... : 2
Switched off heads...................... : No
Heads map............................... : 0,1
Service area:
Power up log reading.................... : Ok
Dir data................................ : No
Permanent overlay....................... : Yes
CFG data................................ : No
SA dir reading (ID)..................... : Module ID 01 reading error Device Error Detected: "DISK ECU UNSAFE ERROR"
SA SPT Detect........................... : FAIL
SA dir reading (ABA/CHS)................ : Module 01 reading error: ABA 3 C:1(1) reading error Device Error Detected: "DISK ECU UNSAFE ERROR"
SA Access............................... : Copy 0,Copy 1
Configuration reading................... : Module ID 02 reading error Device Error Detected: "DISK ECU UNSAFE ERROR"
Any Idea, what I could do?
PostPosted: April 23rd, 2021, 19:12
Techno mode key
RAM:
ROM:
ROM Modules:
Service area:
write donor rom with blocked SA access than used its loader, you will get SA access. I hope than you rule out the problem.
Data Recovery Pakistan
PostPosted: April 26th, 2021, 13:32
Thank you very much MindMergepk. Unfortunately I didn't get access to SA. Please find new output.
Any other Idea?
Techno mode key
RAM:
ROM:
ROM Modules:
ROM F/W version......................... : 00050006
Overlay F/W version..................... : 05.06B
Cache ovl(10) data uploading............ : Ok
Permanent ovl (11) data uploading....... : Ok
Resources folder........................ : C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\WDCMarvell\Palmer\WDC WD10SPZX-00Z10T0-01-01A01-WD-WXH1A88A10X9\Data\SABackup\Modules\Copy 0
Static module reading error Device Error Detected: "VSC ERR STATIC FILE INVALID"
Techno mode key
RAM:
ROM:
Flash ROM dir reading (Ext)............. : Ok (Active)
ROM Modules:
Service area:
SA dir reading (ID)..................... : Module ID 01 reading error Device Error Detected: "DISK DAM ERROR"
SA dir reading (ABA/CHS)................ : Module 01 reading error: ABA 0 C:1(1) reading error Device Error Detected: "DISK ECU UNSAFE ERROR"
Configuration reading................... : Module ID 02 reading error Device Error Detected: "DISK DAM ERROR"
Users browsing this forum: No registered users and 64 guests
