write donor rom with blocked SA access than used its loader, you will get SA access. I hope than you rule out the problem.
Thank you very much MindMergepk. Unfortunately I didn't get access to SA. Please find new output.
Any other Idea?
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 2
Cyl Count............................... : 512
ROM:
Read ROM................................ : Ok
ROM Data size........................... : 1024 Kb
Flash ROM dir reading................... : Ok (Active)
Flash ROM dir reading (Ext)............. : Ok
Modules directory address............... : 0
SA regions address...................... : by default
Module 02 access........................ : Granted
ROM Modules:
ROM version............................. : 05.06B
ROM F/W version......................... : 00050006
Overlay F/W version..................... : 05.06B
Servo F/W version....................... : 03.64
Heads configuration..................... : by map
Heads number in use..................... : 2
Switched off heads...................... : No
Heads map............................... : 0,1
Cache ovl(10) data uploading............ : Ok
Permanent ovl (11) data uploading....... : Ok
Resources folder........................ : C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\WDCMarvell\Palmer\WDC WD10SPZX-00Z10T0-01-01A01-WD-WXH1A88A10X9\Data\SABackup\Modules\Copy 0
Static module reading error Device Error Detected: "VSC ERR STATIC FILE INVALID"
Techno mode key
RAM:
Zone allocation table................... : HDDs RAM reading error Device Error Detected: "SCT INVALID FUNCTION CODE"
ROM:
Flash ROM dir reading (Ext)............. : Ok (Active)
SA regions address (RAM)................ : by default
SA Translator loading................... : No S/A SPT info avalable
ROM Modules:
Overlay F/W version..................... : 05.07B
Service area:
Power up log reading.................... : Ok
Dir data................................ : No
Permanent overlay....................... : Yes
CFG data................................ : No
SA dir reading (ID)..................... : Module ID 01 reading error Device Error Detected: "DISK DAM ERROR"
SA SPT Detect........................... : FAIL
SA dir reading (ABA/CHS)................ : Module 01 reading error: ABA 0 C:1(1) reading error Device Error Detected: "DISK ECU UNSAFE ERROR"
SA Access............................... : Copy 0,Copy 1
Configuration reading................... : Module ID 02 reading error Device Error Detected: "DISK DAM ERROR"
