May 13th, 2022, 19:58
./hugo f -b 4096 -m WUH721818ALE6L4
# ./hugo s
Manuf. Model Serial Interface Capacity Type Firmware
1) Seagate ST9146853SS 6XM1C4EM SAS 146 GB HDD YS0D
2) Seagate ST9146853SS 6XM26BYY SAS 146 GB HDD YS0C
3) HGST WUH721818ALE6L4 3RG72Y4A SATA 18000 GB HDD PCGAW232
4) HGST WUH721818ALE6L4 3RG6X5BA SATA 18000 GB HDD PCGAW232
5) HGST WUH721818ALE6L4 3RG6HYBA SATA 18000 GB HDD PCGAW232
6) HGST WUH721818ALE6L4 3FG8DL1T SATA 18000 GB HDD PCGAW232
7) HGST WUH721818ALE6L4 3RG71YWA SATA 18000 GB HDD PCGAW232
8) HGST WUH721818ALE6L4 3RG6EYTA SATA 18000 GB HDD PCGAW232
9) HGST WUH721818ALE6L4 3RG5Z48A SATA 18000 GB HDD PCGAW232
10) HGST WUH721818ALE6L4 3FG7X4TT SATA 18000 GB HDD PCGAW232
11) HGST WUH721818ALE6L4 3RG7D82A SATA 18000 GB HDD PCGAW232
12) HGST WUH721818ALE6L4 3RG6H6NA SATA 18000 GB HDD PCGAW232
13) HGST WUH721818ALE6L4 3RG742ZA SATA 18000 GB HDD PCGAW232
14) HGST WUH721818ALE6L4 3RG71UXA SATA 18000 GB HDD PCGAW232
# ./hugo f -b 4096 --fastformat --danger-zone -s 3RG71UXA
Format device on 1 Device(s)...
Failed: Format command Failed on device 3RG71UXA.
Device will not be formatted.
May 14th, 2022, 8:52
# ./hugo e -t -s 3RG71UXA
******************************** WARNING **********************************
This will erase data on the specified devices.
These devices might include your boot device and it won't be protected.
This will not work on devices currently running a self-test.
Are you sure you want to erase these devices? (Y/N) y
Device: 3RG71UXA partition table erase FAILED: Error code not mapped: -77830
May 14th, 2022, 10:20
May 16th, 2022, 13:57
