Joined: July 10th, 2020, 7:34 Posts: 51 Location: India
MRT Ultra Version 2.1.5.3
any Seagate Hdd i connect it doesn't give me ROM access or doesn't read via serial port.
MRT USB TERMINAL (ATTACH IS PHOTO)
Normal hdd is attached photo ST3500325AS | 500 GB
-------------------------------LOG
Identifying device... model:ST9500325AS firmware version:0002BSM1 serial number:6VE668LD
Getting detailed firmware version... WY05D7.BSM1.DA99L1.0002BSM1
SMP Dbl: 0x3C000317 - 0x037FF7FF Disk cache reserve size: 0x0
physical sector size of user sector : ..............512 Bytes
physical sector size of service area : .............512 Bytes
Number of physical heads : .........................4 Get System module information ... ID length Description =========================
00 2 01 2 02 16 03 1870 04 9 05 4 06 85 07 1 08 2400 09 1 0A 2251 0B 1000 0C 64000 0D 160 0E 432 0F 223 13 8 15 100 16 2 17 40 19 24 1A 33 1B 1 1C 9 1D 128 1E 128 1F 640 22 80 23 80 24 80 25 80 26 80 27 80 28 80 29 80 2A 9 2B 535 2C 432 2D 432 2E 432 2F 432 30 432 31 432 32 432 33 4576 34 640 35 26
Finished to get system module information!
Getting DT information...
ROM: ID Offset address Length ============================
00 06020100 43520 01 06020000 256 04 04000000 4096 05 0006C000 81920 08 10070000 948 0A 060A1720 1024 12 100D4000 104 13 060AC7A0 768 14 060ACAA0 64 15 00000000 524288 1B 060AB588 4632 1C 060AB448 320 1D 06020120 208 1E 06020380 3216
RAM: ID offset address length ============================
00 06020100 43520 01 06020000 256 02 060201F0 400 04 04000000 4096 05 0006C000 81920 06 00227840 40996 08 10070000 948 0A 060A1720 1024 12 100D4000 104 13 060AC7A0 768 14 060ACAA0 64 15 00000000 524288 16 06020100 32 17 06022A60 1616 1B 060AB588 4632 1C 060AB448 320 1D 06020120 208 1E 06020380 3216 1F 06144678 1728 20 06144D38 72
Finished to get DT information!
Getting service area size....... Service area size: : ................................Fail
Getting list of sys files....... Serial port error! Reading autotuning buffer Buff Root FAT searching in RAM : ...................OK Searching module table in RAM : .....................OK Searching DT table(RAM, WR) in RAM : ................OK Searching DT table(RAM, RD) in RAM : ................OK Searching volume 0 file table in RAM : ..............OK Searching volume 1/2 file table in RAM : ............FAIL Searching volume 3 file table in RAM : ..............FAIL
SERIAL PORT ERROR AND NOT READING service area.
even while reading ROM it fails via bootcode.
even ctrl-z doesn't work in terminal mode.
what is problem
Attachments: |
