In-depth technology research: finding new ways to recover data, accessing firmware, writing programs, reading bits off the platter, recovering data from dust.
Forum rules
Please
do not post questions about data recovery cases here (use
this forum instead). This forum is for topics on finding new ways to recover data. Accessing firmware, writing programs, reading bits off the platter, recovering data from dust...
December 5th, 2022, 9:00
I've got a broken EQL drive to replace with a newer one. As dell does not sell eql drives without a support contract, i'm looking on how to convert an enterprise drive with same part number to an EQL one.
I've downloaded DS04 firmware LOD file and got DE05 firmware LOD from the drive kit update.
Is there anything i can do? Looking at firmware code sections, it is looking to VENDOR ID to proceed with the upgrade.
Can anyone help?
- Attachments
- DS04.lod.zip
- FIRMWARE DS04
- (1.1 MiB) Downloaded 317 times
December 7th, 2022, 11:06
I've managed to flash a
DE05 firmware over
DE07 drive (from compellent) using seaflash for linux.
DE05.lod can be obtained downloading from EQL website the Drive Firmware KIT
- Code:
kit_V13.0_DriveFw_731036618.zip
Looking for the drive device using
- Code:
./sealflashlin_048_064 -i
My disk was at
/dev/sg5- Code:
./sealflashlin_048_064 -s 512 -m ST4000NM0025 -f DE05.lod /dev/sg5
I've captured a kind of partition on a working EQL drive in
EQL.BIN and copied it.
I've used dmesg to get that
/dev/sg5 is mapped to my
/dev/sddNext i've copied the image i made to the disk with
- Code:
dd if=./EQL.BIN of=/dev/sdd
Putting the disk into the storage was successfully with a correctly recognized drive.
Next step is to convert a drive with the Enterprise firmware or a NON OEM segate drive.
- Attachments
- seaflashlin.zip
- (113.17 KiB) Downloaded 348 times
- EQL.BIN.zip
- (100.35 KiB) Downloaded 348 times
December 8th, 2022, 15:57
Usually people do backward procedure. There are many dell drives with specific fw on eBay, cheaper than OEM .
December 9th, 2022, 11:33
DR-Kiev wrote:Usually people do backward procedure. There are many dell drives with specific fw on eBay, cheaper than OEM .
I can't find a working EQL drive on eBay anyway, that's why i asked for help here!
December 28th, 2022, 15:58
Hi.
freddyk, I am trying to make my disks compatible with Compellent arrays.
Seems that they contain an EqualLogic firmware preventing them to work.
Do you have any hint?
March 26th, 2023, 8:53
freddyk wrote:I've managed to flash a
DE05 firmware over
- Code:
- Code:
My disk was at
/dev/sg5- Code:
- Code:
Were you ever able to convert the Non OEM Disk with the EqualLogic firmware?
I am kind of in the same boat. Truing to convert an IBM DS8800 Storage disk into IBM V3700 Disk.
