Tools for hard drive diagnostics, repair, and data recovery
May 16th, 2023, 4:33
hi i have a meccanical hdd is demage i recover data in .imgc but the hdd not have S.O. because is secondary hdd contain only data , when i try to re-flash over a new hdd arrive till the end but if i attach under my pc not saw partion , is possible open a file .imgc and look inside of recover the data? thanks
May 16th, 2023, 15:35
Any data recovery software should open the *.imgc file if the file is a RAW copy of the drive.
What software did you use to make this *.imgc file?
R-studio, UFS explorer and DMDE will open any raw copy whatever the extention is (such as img, bin and so on).
May 16th, 2023, 15:51
Setlec wrote:Any data recovery software should open the *.imgc file if the file is a RAW copy of the drive.
Isn't .imgc a compressed image?
May 16th, 2023, 16:31
ddrecovery wrote:Isn't .imgc a compressed image?
if he used hdd raw copy tool
http://hddguru.com/software/HDD-Raw-Copy-Tool/ then it's a raw. But it will depend on confirmation of
faustf.
May 16th, 2023, 16:36
Examples of possible uses
Software QA engineers: restore your OS hard drives at any moment from a compressed image
May 17th, 2023, 2:44
yes i used Hdd Raw copy Tool thanks at all for answer
