MQ04ABF100 - Write Channel Blocking
December 21st, 2023, 13:47
Hey Guys
Anyone willing to share how to hardware block the write channel on a MQ04ABF100.
I tested with a donor PCB yesterday with the two sets of lines from controller to connector.
I assumed the write channel is the line with voltage, but tried both set anyway.
After cutting the drives just hangs on BSY.
I repaired the lines after and the PCB boots up fine, so its not that I caused other damage cutting them.
Image attached of the lines cut and tested.
Not pretty as its was just an experiment.
Anyone willing to share?
Tim
Re: MQ04ABF100 - Write Channel Blocking
December 21st, 2023, 14:01
You need to find the Write Gate and disable it.
Here is a Seagate example:
https://www.hddoracle.com/viewtopic.php?p=22105#p22105
"PA_WRE - write enable"
December 21st, 2023, 14:20
fzabkar wrote:You need to find the Write Gate and disable it.
Thanks for the info.
Do you have any other examples of other PCB's?
We have 1000s in stock but not this one.
I am guessing it was a Seagate test PCB looking at the silkscreen.
December 21st, 2023, 14:27
See the "-WG" test point on this old PCB (Write Gate, active low, top left corner, near cutout):
https://www.hddoracle.com/download/file.php?id=88&mode=view
https://www.hddoracle.com/viewtopic.php?p=135#p135
December 21st, 2023, 14:33
fzabkar wrote:See the "-WG" test point on this old PCB (Write Gate, active low, top left corner, near cutout):
Many thanks.
I'm sure I probably have others with similar markings.
I will do some testing.
December 21st, 2023, 14:48
I just realized this is what Vlad was referring to in a previous post.
"HW block write channel (WG)"
December 21st, 2023, 17:00
Here is another possibility (Toshiba MK2016GAP):
https://bugworkshop.blogspot.com/2020/07/toshibamk2016gap-20gb-hard-disk-drivepcb.html
It has a discrete R/W Channel IC -- Marvell 88C4210.
Not much info here (as is usually the case with Marvell):
https://www.digchip.com/datasheets/download_datasheet.php?id=95107&part-number=88C4200
However, page 155 of this patent has a pinout:
https://patentimages.storage.googleapis.com/e6/9c/f6/d1ac4d3e7e2509/WO2004100131A2.pdf
December 21st, 2023, 17:11
fzabkar wrote:However, page 155 of this patent has a pinout:
Spooky, someone just sent me that one as well.
I am out of the country later tonight for a while so will pick this up when I get back.
If someone shares confidential info I won't post it unless they approve.
But hopefully we can work it out and share with everyone.
December 22nd, 2023, 6:12
Is it to avoide new heads writing to sa?
December 23rd, 2023, 7:11
Well,
How many drives have you really killed that you are searching for a hardware solution .Can some of my friends out here say really if a hardware solution is required .
January 1st, 2024, 11:41
ddrecovery wrote:Hey Guys
Tim
Hi bro <<
any update here ?
