March 29th, 2024, 0:45
March 29th, 2024, 11:51
[ 2.243820] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2.245957] ata3.00: ACPI cmd ef/10:06:00:00:00:00(SET FEATURES) rejected by device (Stat=0x51 Err=0x04)
[ 2.245970] ata3.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out
[ 2.245978] ata3.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filtered out
[ 2.246285] ata3.00: failed to read native max address (err_mask=0x1)
[ 2.246292] ata3.00: HPA support seems broken, skipping HPA handling
[ 2.246298] ata3.00: supports DRM functions and may not be fully accessible
[ 2.246301] ata3.00: ATA-9: HUH721212ALE601, LEGL0002, max UDMA/133
[ 2.246617] ata3.00: failed to enable AA (error_mask=0x1)
[ 2.246959] ata3.00: Read log 0x00 page 0x00 failed, Emask 0x1
[ 2.246999] ata3.00: NCQ Send/Recv Log not supported
[ 2.247308] ata3.00: Read log 0x00 page 0x00 failed, Emask 0x1
[ 2.247348] ata3.00: NCQ Send/Recv Log not supported
[ 2.247632] ata3.00: Read log 0x00 page 0x00 failed, Emask 0x1
[ 2.247666] ata3.00: 23437770752 sectors, multi 0: LBA48 NCQ (depth 32)
[ 2.247948] ata3.00: Security Log not supported
March 29th, 2024, 15:38
March 29th, 2024, 17:17
April 1st, 2024, 13:26
fzabkar wrote:The drive appears to be faulty. It is unable to execute ATA commands and is identifying itself via the information in its ROM.
I suspect that the drive has been refurbished. It is reporting a diminished capacity of 23437770752 sectors. The full IDEMA capacity of a 12TB drive is 23442069168 sectors. That's a difference of 4298416 sectors or 2.2GB.
