Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
 Post subject: Re: Samsung 860 EVO 1TB all sector reads time out - DEEP DIV
PostPosted: Today, 6:10
I've also done some voltage modification and identified three unique startup power states.
A 0.038a held state
A 0.124a latched state
and a normal 0.219a boot-idle state without SATA
At 0.038a the JTAG transport and debug port come alive very early, before the downstream AP/debug fabric is fully available or powered. This is found by bridging a few points through a 1kOhm resistor. Removing the bridge sends the drive to a full boot.
Under-volting the 1.8v VTref can get you into a latched 0.124a startup state where you get unstable / corrupted JTAG read behavior. The problem is that state isn't recoverable. Restoring the VTref voltage doesn't push it along to a full startup, so no way to
use the misbehaving JTAG to, say, modify some bytes with a malformed write and release the drive to finish booting.
PostPosted: Today, 6:54
HannsGruber wrote:
gold6565 wrote:
I found a firmware file I had—I was interested in it at one point, but after looking at the contents, I lost interest. I didn't even finish reading it through.
Yep, I have that file. It falls out when you unpack the iso. It's still AES256 encrypted, it's sent over to the drive encrypted and decrypted on the device. It has some metadata you can look at, but the body is encrypted.
I haven't seen that in ISO images. That is the format in which the firmware is stored on the SSD.
PostPosted: Today, 8:26
It spills out once you remove the encryption and archive layers. Here's the full file, yours is missing like ~7500 bytes from the end.
RVT04B6Q_01190903.rar [929.35 KiB]
Downloaded 6 times
The updater (fumagician) in the bootable ISO is basically: IDENTIFY DEVICE, READ BUFFER (E4h) to select the matching component, then it decrypts and removes the package wrappers, and sends that .bin component via DOWNLOAD MICROCODE (92h) to the drive.
The attached .bin is the 01 component, specifically.
Users browsing this forum: Google Feedfetcher and 102 guests
