Forum rules
No new topics are allowed in this forum. Please use other forums to create topics.
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3  Next
 Post subject: Read/Write Serial Flash on WDC Logic Boards
PostPosted: June 2nd, 2007, 11:41
Method for Reading/Writing serial flash ROM on WDC Logic Boards...
Tested on:
2060-001159-006 REV A
2060-701292-000 REV A
2060-001293-001 REV A
2060-701335-005 REV A
Method not work with "Mammoth" boards... :cry:
Mikippp
 Post subject:
PostPosted: June 2nd, 2007, 16:01
so cool
 Post subject:
PostPosted: June 2nd, 2007, 16:08
Very clever, beats unsoldering!
 Post subject:
PostPosted: June 3rd, 2007, 5:16
so coool .
 Post subject:
PostPosted: June 5th, 2007, 17:03
WD Scorpio PSV Mode...
Mikippp
 Post subject:
PostPosted: June 5th, 2007, 19:54
thank you Mikippp !
 Post subject:
PostPosted: June 6th, 2007, 9:50
That's useful, thanks!
 Post subject:
PostPosted: June 16th, 2007, 11:35
Hi Mates,
I Got These SMD Probes From a Company Called Panoma From USA .They Have a Kit Which Has All These Probes .Also You Can Make a PCB For The Other Side To Be Used Like What Sivava Willem Eprom Programmer Site Does
 Post subject:
PostPosted: June 17th, 2007, 12:34
Amarbir What do you mean exactly? Could you explain more?
Mikippp
 Post subject:
PostPosted: June 17th, 2007, 14:24
Hi Mikippp
You Could Order These Probes That Just Clip To the Eprom .Then You Can Use a Cheap Programmer Like Willem http://www.willem.org And do What ever You Feel Like .I Hope You Understand
 Post subject: Mamooth
PostPosted: June 18th, 2007, 18:40
Hello does anyone know how to read a Mamooth 3.5 Series? Serial ROM
 Post subject:
PostPosted: June 20th, 2007, 13:53
above in the picture the device is reading the serial rom of mamoth 3.5
 Post subject:
PostPosted: June 20th, 2007, 14:58
On the picture above is Sabre logic board!!!
If Mammoth logic board is not damaged it is possible to read flash with Mavr_fl
Mikippp
 Post subject:
PostPosted: June 21st, 2007, 0:03
Yes its sabre, Mikippp, yes with nazyura soft its possible to read but for write adn whent the PCB its damged, ?
 Post subject:
PostPosted: June 24th, 2007, 12:09
when a flash content is damaged - pcb will not boot, even in psv mode. but if you have spare pcb from wd with serial flash its simple to make a "programmer". just solder on wires DIP8 socket, then using 2 adapters DIP8-SO8, one with good flash to boot, and second with broken one.
First "boot" in psv mode pcb with good flash, then hot-swap to another one. Its good idea to read broken flash before programming because many times corrupted bytes are in first bytes and original adaptive data can be recovered from original drive (last 512bytes as i think)
Another solution is using seagate 7200.7 pcb and its place for serial flash. When "booting" pcb in safe mode with soldered flash from eg. wd or from gfx card, its needed to short circuit DATA pin to ground and drive start with rom from uP. (just like safe mode on ibm/hitachi)
 Post subject:
PostPosted: June 26th, 2007, 13:48
Hi Aviko,
Brilliant Idea About The Seagate Being USed As a EPROM Programmer .Are These Serial Flashes ,If YEs Ponyprog is Good
 Post subject:
PostPosted: June 26th, 2007, 14:02
long time ago same solution was with fujitsu mpg pcb. i did not mention that you have to reprogram flash with pc3000 and seagate utility, so dont underestand use of ponyprog.
 Post subject: Re: Read/Write Serial Flash on WDC Logic Boards
PostPosted: October 3rd, 2007, 7:23
Online
Hi Aviko,
can we use Maxtor Calipso PCB instead of seagate 7200.7 pcb?
It seems easier to me. No need for adapter.
PostPosted: October 3rd, 2007, 15:05
BGman U can use Maxtor Calypso PCB instead of seagate 7200.7 pcb... but if U use Calypso PCB it is necessary make bytes swap.
Mikippp
PostPosted: October 4th, 2007, 4:24
Online
What exactly means bytes swap ?
