Forum rules
No new topics are allowed in this forum. Please use other forums to create topics.
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Read/Write Serial Flash on WDC Logic Boards
PostPosted: October 4th, 2007, 14:43
Byte swap: byte order swap
00 01 02 03 04 05 -> 01 00 03 02 05 04
PostPosted: October 5th, 2007, 3:45
Thanks pepe!
Is there a program that can do this for me?
PostPosted: October 5th, 2007, 5:04
U dont have to use adapter with seagate pcb too, adapters were needed when u had to make hot swap flash while pcb was powered on (because wdc logic board will not start without rom or with corrupted rom content)
Thats why u have to short 4&5 legs of flash when powering on seagate pcb (because program will hang up with corrupted rom) when its shorted, program will start from internal rom builtin uP)
Remember this is only temporary solution when u havent proper tools to do what you need. (but works and its cheap even free, just using _own_ brain is needed). If you take your business seriously, consider buying universal flash programmer. its really cheap now. eg. elnec or xeltek
This post was my opinion today. It cant be used against me in tomorrow or later. In addition, I reserve the right to change views without giving any reason.
PostPosted: February 18th, 2008, 12:39
Original text->
http://support.salvationdata.com/downlo ... change.pdf
PostPosted: April 7th, 2008, 13:28
WDC 2.5" SATA HDD - PSV Mode...
[ '''''''''''''''| |''''''''' ] [....] ---> GND
Mikippp
PostPosted: July 11th, 2008, 20:42
According to the Salvationdata document posted here, you can not write content back to the ROM chip without un-soldering. They state because write protection is active on the M25P10 chip. Can someone verify the validity of this?
Also, what is with other chip sets any experience?
Thanks!
PostPosted: July 16th, 2008, 19:52
I never had problems with writing serial flash roms in WDs without desoldering...
PostPosted: March 18th, 2009, 1:49
That stuff is awesome, I want one of those, where can I find this ?
 Post subject: Information for new comers on hard drive failure
PostPosted: March 27th, 2009, 19:00
Here is an interesting paper I ran across for new comers on why hard drives fail. You might like to read it
23.rar [290.43 KiB]
Downloaded 3124 times
Iorana Haraharaini
 Post subject: Re:
PostPosted: December 22nd, 2009, 3:07
Amarbir wrote:
Hi Mates,
I Got These SMD Probes From a Company Called Panoma From USA .They Have a Kit Which Has All These Probes .Also You Can Make a PCB For The Other Side To Be Used Like What Sivava Willem Eprom Programmer Site Does
Just to clarify, the manufacturer is Pomona ( http://www.pomonaelectronics.com/ ) which is now owned by Fluke. This clip is in 8-pin SOIC format.
PostPosted: March 16th, 2010, 23:55
Well ,
I Would Say Use a Universal EPROM PROGRAMER Lol + SOIC8 Adapter
PostPosted: May 1st, 2010, 2:03
what is "PSV mode"? please tell me.thanks!
PostPosted: May 1st, 2010, 2:46
Use search.
PostPosted: May 2nd, 2010, 2:04
In a uP system, you can sometimes read and write data stored in program memory by direct access using a feature called Program Space Visibility (PSV).
For example, you could use HDDHackr to write a ROM patch for a Western Digital WD1200BEVS drive to enable it to be used in an XBOX360.
PostPosted: May 2nd, 2010, 2:40
I think I may have misread the documentation. It appears that HDDHackr accesses the ROM modules on the platters, not the PCB ROM.
PostPosted: May 2nd, 2010, 11:58
To access the embedded PCB rom it takes A LOT MORE :mrgreen:
PostPosted: March 13th, 2013, 1:31
Has anyone used a Needham's EMP 21 programmer for reading/writing serial flash ROM on WDC Logic Boards? If so what are the connections from the ZIF socket to the SMD probe(IC clip)? I'm assuming the EMP 21 can handle a 25W406A IC.
P.S. What are the connections in the photographs ZIF socket to SMD probe(IC clip). Thank You
PostPosted: March 19th, 2013, 16:21
Very useful topic, is there any place to buy that clip-adapter for the programmer? and its model please?
PostPosted: September 13th, 2014, 3:53
hi, all new to this forum.
maybe someone can help me shed some light on this ?
i was wondering if it was possible to edit the flash inside the hdd so lets say i would want to clone it ? like for example the serial no. of a certain drive ? to another hdd ? (what needs to be done if possible? )
can someone please explain to me where the unique serial is written in a hdd ? was this generated from the factory or is it a serial of burned in a chip or the disc itself ? is it possible to replace the serial of a certain hdd ?
I was wondering why a donor board will not work on a WD400BB if the flash is not transferred? what is causing the incompatibility assuming it has the same capacity and model ?
thank you
PostPosted: March 30th, 2015, 4:57
Thanks Mikippp,
Your advice has helped me to solve issue.
Users browsing this forum: No registered users and 6 guests
