 Post subject: Detect in bios but not OS
PostPosted: March 11th, 2009, 22:05
I need some help to solve this problem.
I have a 40gb Maxtor DiamondMax and not detect in bios. So, I check, some of the firmware are bad, write it back and make it detect again. Try to run in MHDD, found a few bad blocks but I can't erase it because I need the data.
But the problem is when I run the hard disk to pull out the data, the hard disk only detect in bios not in OS.
I've tried many times, check the cable, jumper, try at other computer but it still the same.
So, I need to know what cause of that problem. Is that because of bad sector the hard disk not detect in OS?
Please, I need some advice because the data is very important to me.
 Post subject: Re: Detect in bios but not OS
PostPosted: March 11th, 2009, 22:21
What firmware tools are you using?
PostPosted: March 11th, 2009, 22:22
pc3000
PostPosted: March 11th, 2009, 22:51
post a pic or list of the bad mods
PostPosted: March 12th, 2009, 1:52
module 67, 63, 5E, 41,34,2F,1D,1B,1A
PostPosted: March 12th, 2009, 3:28
You should know what to do then...
PostPosted: March 12th, 2009, 5:11
exactly what I was going to say...
PostPosted: March 12th, 2009, 5:21
Just a little help:
If these modules are all bad, your drive have bigger problem than the SA corruption....
It is time to seek for professional help. :D
Janos
PostPosted: March 12th, 2009, 6:27
Who has PC3000 that is not professional?
Damn expensive toy for a hobbyist. I mean, seriously, some people think I'm nuts with a high end DSLR not being a professional photographer, but that would be next level overkill.
PostPosted: March 18th, 2009, 3:04
If he has a legal instance of the tool, he should know how to handle this kind of problem... :roll:
Users browsing this forum: Google [Bot] and 474 guests
