March 10th, 2009, 18:11
March 11th, 2009, 0:00
March 11th, 2009, 3:39
March 11th, 2009, 3:43
March 11th, 2009, 7:58
xehqter wrote:1.6 is buggy as hell.. it crashes constantly, 1.6.1 is a lot more stable. When/if they crack SanDisk Crypto I'll give them a pat on the back otherwise I'm not impressed. PC3K flash is only good for 10% of my cases, granted it is nice when it works I wish all I got were USBest or SM32x those are easy.
Auto Detect works well on "known" controller/size combo's, otherwise its useless, it mangles the image beyond recognition or does nothing.
March 11th, 2009, 10:44
March 12th, 2009, 3:43
hddguy wrote:xehqter wrote:1.6 is buggy as hell.. it crashes constantly, 1.6.1 is a lot more stable. When/if they crack SanDisk Crypto I'll give them a pat on the back otherwise I'm not impressed. PC3K flash is only good for 10% of my cases, granted it is nice when it works I wish all I got were USBest or SM32x those are easy.
what tool do you use?
March 12th, 2009, 4:34
Creator wrote:xehqter wrote:1.6 is buggy as hell.. it crashes constantly, 1.6.1 is a lot more stable. When/if they crack SanDisk Crypto I'll give them a pat on the back otherwise I'm not impressed. PC3K flash is only good for 10% of my cases, granted it is nice when it works I wish all I got were USBest or SM32x those are easy.
I couldn't imagine, how do you solve only 10% of cases? I suppose that you're didn't read the manual. In the PC3k flash there are universal algorithms which are very good. Much better than in another tools. As I can see you're newbie and you use only "Recovery via controller mode". You should just run autoanalysis and it will solve much more your cases.
Read more about "how to use new version" there:
http://www.pc-3000flash.com/eng/ver161.090302.php
March 13th, 2009, 2:23
March 13th, 2009, 3:21
darkforce1 wrote:Hi
I am also using PC3000 Flash Version 1.6.1 but there is no such issue of crashing. its quite stable. as I am running on Windows XP SP 3. Try to load SP3 and may be your problem solved.
March 20th, 2009, 3:34
