Post new topic Reply to topic  [ 94 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: ATA password bypassing
PostPosted: May 19th, 2009, 14:54
Well I finally dug out my old, locked, xbox WD 8GB drive (WD80EB)
and fired it up with MHDD
MHDD says PWD (ie locked)
Security: MAX, ON
Max = need unique and currently unknown user password only
as opposed to the other possibility of HIGH where either the Master or User password can be used, and the Master may or may not be the factory default
So I guess there is no way to unlock it, to get to any data
(I dont have the user password)
without something like a PC3000
Note - I dont need the data or the drive really, this is just for testing of if it was possible
I'll probably force erase the drive (which should be poosible)
so that I can use it to play with setting Master and User passwords
Any maybe some kind person will give any tip of any other possible method
(shorting of other jumper pins etc)
although that will be specific to this drive
and wont help me in the future if I ever get a real, important, locked drive to look at
(my friends are always asking me to recover corrupt partition tables etc)
PostPosted: May 19th, 2009, 15:04
And looks like a cant do an erase in MAX security mode (from MHDD)
ie cant send a SECURITY ERASE PREPARE command, immediately followed by SECURITY ERASE UNIT
or maybe I've overlooked how to do it from MHDD
PostPosted: May 19th, 2009, 15:17
I will help you and for free to get rig of that password !!!!
First just to grab a copy of MHDD prior to the latest version.
Download MHDD 4.5 from here :
http://hddguru.com/content/en/software/2005.10.02-MHDD/
You will need it because it contain the ATA terminal that you will need for our little experience. Also use the floppy version, if you use the CD ISO you will end up with a "virtual ram drive" when you boot the MHDD and not the real a: assigned to the floppy.
Then open your notepad and past the following script :
; rm modul id 42
reset
waitnbsy
regs = $57 $44 $43 $00 $00 $a0 $8a
waitnbsy
regs = $00 $02 $00 $00 $0F $E0 $21
waitnbsy
checkdrq
sectorsto = 42.bin
; End.
save the file with a simple name, like "wdpwd" and remove the .txt extension to the file. You should end up with a filename witjout extension. Save that file to the "Scripts" folder of your MHDD 4.5
Now boot your MHDD copy and detect the locked drive. Mhdd will tell you the drive is locked. Don't worry and issue a .wdpwd or whatever you named the file.
You should end up with a file named 42.bin on the disk you used to boot mhdd.
If you have booted from cd you will have to copy the file out of it to a floppy, etc ...
Post the content here, if you can't figure out where the password is ;)
Happy unlocking for free !
Without expensive tools.
That experience will also give you an idea about the true importance of vendor-specific ata commands.
PostPosted: May 19th, 2009, 15:27
Wow, thanks
I'll give that a try
Now that is the sort of friendly interaction and helpful advise I was expecting on here
I've also dug out another old drive
Maxtor 6L040L2
that supports ATA passwords
Shows Security: high, Off
I am able to set and remove user passwords
Can't seem to unlock with a Master password, but then I don't have the Master password (and cant seem to find it on the web etc)
And looks like I was wrong in that it in not possible (or not easily possible) to change the default Master password
Not that the Master password helps you when in Max mode
PostPosted: May 19th, 2009, 15:39
Sorry one more question
(I want this thread to be the definitive ATA Password thread)
In MHDD with my Maxtor drive Security: high, OFF
is there a way to put it in MAX security mode ?
PostPosted: May 19th, 2009, 15:42
Maxtor 6L040L2
You can try to read the MAXTOR password with HDDRepair 2.0 from here :
http://files.hddguru.com/download/Softw ... pair.v2.0/
PostPosted: May 19th, 2009, 17:00
THis is what the end of the 42.bin of my WD drive gives
00000390 00 00 00 00 00 00 00 00-57 44 43 57 44 43 57 44 *........WDCWDCWD*
000003A0 43 57 44 43 57 44 43 57-44 43 57 44 43 57 44 43 *CWDCWDCWDCWDCWDC*
000003B0 57 44 43 57 44 43 57 44-A9 4A D6 A8 31 9D 6B 3A *WDCWDCWD.J..1.k:*
000003C0 93 D1 13 9D 15 0F 55 B8-CF 89 D4 96 00 00 00 00 *......U.........*
000003D0 00 00 00 00 00 00 00 00-57 44 43 20 57 44 38 30 *........WDC WD80*
000003E0 45 42 2D 32 38 43 47 48-31 20 20 20 20 20 20 20 *EB-28CGH1 *
000003F0 20 20 20 20 20 20 20 20-20 20 20 20 20 20 20 20 * *
(the *'s are from my hex editor)
Shows the default master password
Then 32bytes of hex (could be the user password, but not in a user enterable form)
Then the details of the WDC WD80EB drive
or have I missed something ?
Since it was locked by an xbox 'bios', I guess the random password it used doesnt have to be ascii ?
PostPosted: May 19th, 2009, 17:12
WDCWDCWDCWDCWDCWDCWDCWDCWDCWDCWD
This is the Master Password for your drive.
In High security mode, you can unlock the disk with either the user or master password, using the "SECURITY UNLOCK DEVICE" ATA command. There is an attempt limit, normally set to 5, after which you must power cycle or hard-reset the disk before you can attempt again.
In Maximum security mode, you cannot unlock the disk! The only way to get the disk back to a usable state is to issue the SECURITY ERASE PREPARE command, immediately followed by SECURITY ERASE UNIT. The SECURITY ERASE UNIT command requires the Master password and will completely erase all data on the disk.
PostPosted: May 19th, 2009, 17:17
If you don't want the data on the drive you can use the master password on MHDD to secure erase the disk. All data will be erased but you can use the drive again ;)
Just open your MHDD and secure erase the disk, supply the master password and don't close MHDD. When the Busy light disapears you will know that the process is finished and the password should be disabled too.
PostPosted: May 19th, 2009, 17:28
By the way, this Vendor Specific Command should bypass the security settings of the drive.
So after you run the script that i gave to you on MHDD you should be able to scan the drive like if it was an unlock drive. If you manage to do so you can copy the data out. If you don't re-power the drive the drive should still be working under the Techno Key and should be "unlocked".
If data is important and if you want to play arround a little bit with it we can try to read other modules with a variation of the $00 $02 $00 $00 $0F $E0 $21 command. If the USER password is stored somewhere on one of the firmware modules we might be able to find it ;)
I will get an old WD drive and try to lock it with a known password, download all modules and check if the password is stored there somewhere and if so, where.
PostPosted: May 19th, 2009, 17:41
Try writing your own password to it and seeing what changes.
PostPosted: May 19th, 2009, 17:48
Maybe the password is encoded there :)
I will have to test it too ... if only i had more time ....
I'm preparing a full review of my experiments with Seagate to post here, when i finish i will start to do some experiments with WD ...
If data is important try to use the script that i've send you and you should have access to the data until you re-power the drive (re-initialize). Than you can use the secure erase function on MHDD and supply the Master Password that you now have and know for sure to be valid for your drive WDCWDCWDCWDCWDCWDCWDCWDCWDCWDCWD and you should have a functional drive when the command completes. You can try to dispassword the drive with master password and MHDD will tell you that you will delete all your data if you continue.
Either way you will end up with a working drive on the end that you can use to play with ;)
PostPosted: May 19th, 2009, 17:56
I think you are correct. The password can be is HEX instead of ascii. Either that or encoded. Most likely it's because your XBox locked it with HEX password.
I'm just gessing because i still didn't have the time to "play" with the passwords on those drives yet.
I'm working on Seagate on the moment and i will only start to stidy another manufactory when i have time.
PostPosted: May 19th, 2009, 18:48
Thanks for all the really useful info
I assume the '42' is a refernce to some particular SA block
although theres no $2a in the command sequence
If I modified the 42.bin file, is there a command sequence to write it back to the same place on the disk !
I'm sure there is, but not sure if you would be willing to share it ?
Hopefully this block isnt checksummed
Similarly I'd really like to know what the cmd codes do
eg which is the rd cmd and which specifies the SA block or -ve track etc
(and the info isn't too valuable as these 5GB drives are ancient, unless it works on all WD drives ...)
In fact youve already said that
is the bit that specifies the block to read
ANd good luck with your Seagate work.
PostPosted: May 19th, 2009, 19:06
This is the wdc_super_on= 0000 57 44 43 00 00 a0 8a
First you issue this command to be able to access the firmware, etc ... It will place your drive under a special vendor mode.
That command is the equivalent to $57 $44 $43 $00 $00 $a0 $8a
It's an ATA command, a specific one.
0000 00 02 00 00 0F e0 21
Will read module 42 - Configuration Module on the SA of the drive.
The commands will work on *Many* WD drives, all WDC based. For Marvell you will neeed another set of commands.
PostPosted: May 19th, 2009, 19:08
You can use this tool to check all modules on your WC drive :
http://nazyura.newmail.ru/Chk_wd.zip
PostPosted: May 20th, 2009, 15:13
Thanks yet again
After the wdc_super_on ($57 $44 $43 $00 $00 $a0 $8a)
I can then successfully read some sectors, but not all
Doing an F4 scan I get the following
(where M is a grey block of varying intensity ie a 255 sector block read ok)
MAMxMxMAMx
----> further on
same
further on
similar
further on - all reads ok (from about 24% into the 5GB drive)
is this expected ?
I haven't actually looked at the raw data in the readable blocks yet
Also my WD80EB has started staying BUSY for long periods after a 'spark' when plugging in to a live system
(thought I'd totally fried it at first)
In fact its stopped responding now and F4 gives me clicking .... as does power cycling it.
Looks like I'll have to get another disk for experiments
This is the most hacking fun I've had for many a month :-)
PostPosted: May 20th, 2009, 16:29
If the block that you think that contain the USER password in HEX form does indeed contain the USER password you can edit the module, replacing the password and write it back to the drive if you manage to figure out the specific vendor command to write it back.
Maybe the drive is bad or maybe scan it with Super On enabled it wasn't a good idea to start with ;)
PostPosted: June 11th, 2009, 23:09
Spildit,
hey i been searching to unlock a maxtor
the ata password tool shows this
maxtor 6y230p0
rev yar41bw0
ata password tool v1.1
shows plus signs under
S, E, L, F, X, V
+ + + - - h
i wanted to know if its possible for me to unlock the drive? thanks and sorry to bother you but you wrote in a few topics to pm you to unlock a specific drive if you could help me out let me know.
PostPosted: July 13th, 2009, 16:46
@ateam201
Users browsing this forum: caffelatte, Fartow, Google Adsense [Bot], sstore and 34 guests
