Post new topic Reply to topic  [ 84 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Seagate 7200.12 - need help with diagnosis and/or fix
PostPosted: October 20th, 2011, 5:27
ROb wrote:
I can help you solve this problem PM me...
I am also experiencing this issue. Any more information regarding a fix?please help,,,,,,having pics of my granny who died last week...............................please help me brother rob..........thanks
PostPosted: November 4th, 2011, 9:36
Unless ROb has already helped you, you can ask user ajayvats for help. Although the solution may not be applicable in your case, he can possibly share some ideas.
PostPosted: November 4th, 2011, 9:38
ajayvats wrote:
bochen415 wrote:
You can always PM me or the author of the fix and ask
HI,
Me too having same problem with my ST3250318AS CC44 hdd. Can u pleade give the fix for the 7200.12 series as i am in need of the same.
PS. COuld not find any link to send pm.
Replied to PM.
PostPosted: November 7th, 2011, 17:33
I have the ST3250318AS FW:CC38
Recognised by Seagate Doctor and DC
FW errors
Bricked!
Can anyone help with the FW?
Thanks,
Mario
PostPosted: November 7th, 2011, 18:39
You have all the resources needed on the forums and SalvationData documentation since you have their product.
Have you searched at all?
PostPosted: December 9th, 2011, 3:54
neowakesup wrote:
Seriously guys, plz share the solution IN the forum...
Here's the fix only for the ST31000528AS 1TB Barracuda 7200.12 Firmware: CC38 model:
ROb wrote:
start your drive by shorting read channels
F3 T>/2
F3 2>Z
Spin Down Complete
Elapsed Time 6.035 secs
[Remove the shorting and give following command]
F3 2>U
HighPowerMode
ExecuteSpinRequest
Spin Up Complete
Elapsed Time 3.573 secs
F3 2>/
F3 T>m0,2,2,,,,,22
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 16, Max Certify Rewr
ite Retries = not supported
User Partition Format Successful - Elapsed Time 0 mins 00 secs
F3 T>/1
F3 1>N1
Clear SMART is completed.
F3 1>
[disconnect the power, wait couple seconds and connect again]
Rst 0x08M
(P) SATA Reset
Now if your drive is working go and copy quick all the data you can and if not throw it out tho the garbage or send it to the manufacturer.
Shorting read channels:
short the pins shown here
http://qbhn.neostrada.pl/ST31000528AS.jpg
this is the component side, it goes through the pcb to the other side, I think here
http://qbhn.neostrada.pl/02.jpg
but not sure - thrust the first image its 100% ok
PostPosted: December 13th, 2011, 7:44
@moiz - replied to PM
PostPosted: June 7th, 2012, 10:14
Hi, I have the same problem
Rst 0x10M
No HOST FIS-ReadyStatusFlags 2002B001
on a DiamondMax23. Can you help me?
PostPosted: June 7th, 2012, 10:22
I can't PM anyone. Labtech, help me please!
PostPosted: June 7th, 2012, 11:47
Replied to PM
PostPosted: August 9th, 2012, 18:41
F3 T>/2
F3 2>Z
Spin Down Complete
F3 2>U
HighPowerMode
ExecuteSpinRequest
Spin Up Complete
F3 2>/
F3 T>m0,2,2,,,,,22
F3 T>/1
F3 1>N1
F3 1>
Rst 0x08M
(P) SATA Reset
Many many thanks
i tried on ST31000528AS fw:CC35
It WORKS
upgraded to CC49
PostPosted: August 28th, 2012, 15:22
As with many others, my Seagate Barracuda 7200.12 750 GB Firmware: CC46 stopped being recognized by Bios one day. I've spent few days trying to find out what was wrong, and hours trying different combinations in Putty. I need to mention that the drive had no important data on it when it happened so I decided to give it a try, and no warranty. Finally, I found this thread and followed the instructions below. Everything was going well upto F3 T>m0,2,2,,,,,22 where I kept receiving DiagError and partition failed. What I did then was unplugged Sata power prior the F3 T>m0,2,2,,,,,22 step, waited 10 secs, plugged it back, ctrl+z to get to F3 T> then F3 T>m0,2,2,,,,,22 and ENTER. Everything went well after that. I turned the pc off, plugged the drive back and turned it back on, but the same issue - not recognized by BIOS. I can hear the drive spins and there is one more repeated low sound - not a click. I'd like to know what this sound can possibly mean and if there is anything else can be done to fix it. Thanks for your support!
Paky wrote:
F3 T>/2
F3 2>Z
Spin Down Complete
F3 2>U
HighPowerMode
ExecuteSpinRequest
Spin Up Complete
F3 2>/
F3 T>m0,2,2,,,,,22
F3 T>/1
F3 1>N1
F3 1>
Rst 0x08M
(P) SATA Reset
PostPosted: August 28th, 2012, 15:23
Does the drive spin down?
PostPosted: August 28th, 2012, 15:29
Yes, it does
PostPosted: August 28th, 2012, 15:30
Pretty sure the drive has internal read-write hardware issue and/or media damage.
Was it dropped or sustained any kind of physical shock?
PostPosted: August 28th, 2012, 15:47
I see.
No, it was not.
PostPosted: August 28th, 2012, 16:16
Without experience in this field, no DIY solution I am afraid.
PostPosted: August 28th, 2012, 16:41
cloverex:
Did you complete procedure with reseting SMART before cycling power? If not, I guess, you need to repeat entire procedure.
PostPosted: August 28th, 2012, 16:50
Is it possible that PCB is fully functional?
If the issue is in the heads, do you think it is worth it to get a donor drive to do the swap?
Thank you very much for your support!!!!!!!!!!!
PostPosted: August 28th, 2012, 16:58
SAjunky wrote:
cloverex:
Yes, I did.
F3 T>/1
F3 1>N1
F3 1>
Rst 0x08M
(P) SATA Reset
Users browsing this forum: Google [Bot] and 56 guests
