 Post subject: St500dm002 not recon on bios,I own RS232 dev,what can i do?
PostPosted: May 5th, 2017, 17:57
I have a st500dm002 7200.12, my hdd have stop working when PC start it's not reconiced by bios.Start doing a ckiking noise then stop working. The PCB looks fine, i put to the HDD another but still bad.
i have a RS232 device operational, what can i do to fix my drive
I live in Cuba, i can't send my device to another country to be checked by specialists, so please the only way to fix my drive is you people help me. I'm Telecomunication engineer, i have enought knowledge of electronic and digital circuits.
I have sucsefully plugged the RS232 device to another HDD (Seagate 7200.10) I have read this on internet, but it looks like it doasen't work>
" F3 > Ctrl + Z
F3 >/T "para irnos al nivel de Test"
F3 T> m0,2,2,0,0,0,0,22 "este es el comando importante"
Please there is a pro on this forum who can help me fixing the hard drive, it's realy important for me, it doasen't matter if i have to loss the data. Thanks :(
 Post subject: Re: St500dm002 not recon on bios,I own RS232 dev,what can i
PostPosted: May 5th, 2017, 18:09
If it's clicking then it's physical issue, not DIY.
Nor feasible to "fix" it either.
PostPosted: May 5th, 2017, 18:41
I have readed cases of cliking disk with the G-list defective,but:
The HDD doasen't have fall, or any kind of hit.
I whas instaling Gears of Wars then a blue screen. The HDD whas no more.
PostPosted: May 8th, 2017, 11:29
Anyone can help me on this please? :(
PostPosted: May 8th, 2017, 13:13
First Check
drive spinning or not?
any clicking or not
Depending on your right answers here you will get help
PostPosted: May 8th, 2017, 13:50
First Check
any clicking or not
This is what i've done.
1 I cheched PCB, everything looks fine
2 The HDD Spin on, then: clic,clic,clic and it turn off
3 -To test, i tryed an EXACT PCB on my disk (From another hdd same model same P/N same firmware) it do the same
4 -I pluged my RS-232 on the PCB it works fine, i get the F3> (It's asking me for a valid CERT code) it give the powerOn time a valid serial number. What can i do now
PostPosted: May 8th, 2017, 14:42
titokhonan wrote:
First Check
any clicking or not
2 The HDD Spin on, then: clic,clic,clic and it turn off may be your heads damaged
when you swap pcb u need change eeprom toofrom old pcb
PostPosted: May 9th, 2017, 14:43
change eeprom too from old pcb ?????
Wow wait, why it's that needed???
where it's ubicated the eprom?
PostPosted: May 10th, 2017, 1:59
Post ur image of ur pcb
The information about ur Hdd stored in eeprom like FW,HDD serial No. Heads information
PostPosted: May 10th, 2017, 6:09
Click, click, click and then turns off..... I vote for bad heads... not DIY.
PostPosted: May 10th, 2017, 11:36
Well,
It could be one or more bad heads ,But he said its says its asking for valid cert code this error comes from old hods that are non F3 not F3 ,I am super confused
PostPosted: May 11th, 2017, 22:02
Amarbir[CDR-Labs] wrote:
Well,
Wait latest news!!!!!
After i switched back the original PCB, the hdd is not stoping now, it's clicking realy fast, hards clicks, fasts cliks. Still not getting detected by "mr. BIOS", and "Hdd detection time" PC have increased.
/= hard short click
*= fast click
--= time
1minute time
i have uploaded a audio
20170511.zip [285.96 KiB]
Downloaded 918 times
PostPosted: May 12th, 2017, 2:09
Well,
/= hard short click
*= fast click
--= time
1minute time
Did u changed original Eeprom to original PCB?
From all of your report I understand Heads defect
find donor drive and replace heads
If you don't have experience better to contact DR in your country
If you repeated ur trails you may lost all ur data
Better to stop trails
PostPosted: May 12th, 2017, 12:44
prasadsv wrote:
Well,
/= hard short click
*= fast click
--= time
1minute time
Bro whe may have a big problem. Why?
1st I live in Cuba, there is no DR in my country
2nd an HDD here it´s REALLY expencive!
example 1TB= 110$US$ my income it´s 345$CUC$(Cuban currency)=13.8$US
People here have computers, they have family on another´s countries who send money so they can buy them, i don´t have nobody outside this country so i REALY need your help guys.
I have to work 8 months without eating to buy a newone. So i´ts almost imposible for me buy a 1TB hdd to supply the one my son broke. So i have to fix it! buy another is not an option!
So please guys stop telling me to buy another hard drive diferent than Seagate, or take it with DR specialists on my country, probably right now the only one who is doing something like this in Cuba is me. Thanks to all touse who answer this tread.
Data it´s not important here, more important it´s the HDD, Heads can be deativated??
PostPosted: May 12th, 2017, 12:46
prasadsv wrote:
Well,
/= hard short click
*= fast click
--= time
1minute time
PostPosted: May 12th, 2017, 13:33
Spildit wrote:
Tools to deactivate heads would cost you way more then a new HDD ...
PC-3000 for example would cost you $6000 USD. MRT Pro would be about $3000 so ....
Also that click click click by now with many power off/on already turned the platter surface intro dust so ... "sayonara" hdd ...
Not to mention that most likely pre-amp is gone and with it ... the entire head stack in useless and you are out of options....
There are NO WAY for you to fix the drive. For data recovery you would have to buy a drive to use as donor and and extra one to copy the data to + tools + have experience, etc ....
CERT code mentioned on the 7200.10 drive is because 7200.10 is ST-10 (old type9 and NOT F3 ARCH.
If your 7200.10 drive is still working use that instead as your broken F3 arch drive.
You are NOT GOING to be able to fix the 7200.12 NO MATTER WHAT.
ImageWhy?
It looks like it´s your job to steal people hope to fix their hardDrives, all your answers in all treads are the same:
-Take it to a DR specialist or buy a newone, not Seagate.
-Your hardDrive it´s broken it will never have solution
Im not going to surrender on that drive fix. Almost all what PC-3000 do, can be done with a proper Terminal. I may not have the experience, but all the damm knowledge got on the Univercity, have to be usefull, fixing this, if you will not help me i will find someone who can.
PostPosted: May 12th, 2017, 13:57
Listen....
Your drive has physical problems (bad heads).
It is NOT VIABLE to repair this drive. End of. Period. Game over. It's dead. Understand????
You CANNOT repair a bad head with terminal commands, like I cannot fix my cars engine with soap and water.
You have come to this forum for advice, and you've been given it.
Yet you have chosen to ignore the advice given because you didn't like what you were hearing. You seem to think you know better than the very people you came to for advice.
Just move on and look for a second hand drive or something.
I wish you the best of luck, but please admit defeat on this!! :-)
PostPosted: May 12th, 2017, 14:09
pcimage wrote:
Listen....
i´m not defeated yet!
have you people read this thread
(Cut bad head)
viewtopic.php?f=1&t=35282
It looks like HDD head can be soft cutted (disabled)
the big deal now could be, find the bad head, and how can be cutted by terminal.
PostPosted: May 12th, 2017, 15:01
(Cut bad head)
Oh ...
http://www.hddoracle.com/viewtopic.php?f=2&t=2037
The thing is your drive have either a damaged pre-amp or all heads are gone ...
So .... cut ALL heads and try !!!
:lol: :lol: :lol:
Also this is assuming you don't have MASSIVE surface damage by now because of all of that PCB swapping without native ROM ....
What is a damaged pre-amp?
PostPosted: May 12th, 2017, 15:40
Spildit wrote:
No, you are NOT !!!
http://www.hddoracle.com/viewtopic.php? ... 051#p13125
Maybe you should ask some help to @oleg as he might have some refurb drives to sell you at a decent price.
OK OK, I surrender!!!!
Can u please send me via PM, like a tutorial to fix conmon HDD seagate problems. I will thank you a lot for that.
You are a cool dude. Greetings from Cuba.
Users browsing this forum: Google [Bot] and 78 guests
