It is currently June 19th, 2013, 1:26
Post new topic Reply to topic  [ 188 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10
 Post subject: Re: Tutorial: resolve 0 LBA,SEAGATE 7200.11 BIOS don't recognize
PostPosted: April 7th, 2010, 8:11
ninjabreadman wrote:
is there any reason why i cant just "pinch" the HD controller off another identical 500gb seagate 7200.11 drive that isnt stuck in busy mode to get my data off - yes i know it doesnt resolve the drive issue but im more concerned about my data than a $NZ100 hard disk
i need my data back now and can wait to resolve the drive issue either by RMA/replacement to the supplier, or the RS232 method described
thanks in advance!
Havent you read anything on this forum? Each PCB is unique to each drive, also changing pcb does not correct common firmware issues.
PostPosted: May 7th, 2010, 12:21
Thanks for your help in solving this issue, my seagate works again..now i'm still not sure if I should update the firmware on the drive as i've read others having problems.
PostPosted: May 7th, 2010, 23:50
Very detailed explanation,thanks admin!!
PostPosted: April 26th, 2011, 8:50
Hello friends I want to tell you how I managed to recover data from my hd seagate, because even though experience in the bio, it made a strange noise, ticking, and did not have a valid partition, what I did was update the firmware through the. iso seagate's website, and then used as a tool for data recovery program from seagate recorery file (easy to find on torrents site) is there to help me, sorry ITS verry bad English, translate for google. thanks.
PostPosted: April 26th, 2011, 13:53
Location: Zagreb,Hrvatska popravljam diskove "bussy,0LBA" http://www.hddrepair.dzaba.com/
Thnx guys!
popust 50% na popravak bussy i 0LBA
PostPosted: May 22nd, 2011, 4:16
Drive is busy example, not solution: drive ST3500320AS SD15
remove 3 screws nearest heads connector, motor connected, put something between pcb and hda to lift pcb and prevent contact.
power on, wait until drive stops motor
(ctrl+z)
F3 T>/2
F3 2>Z
Spin Down Complete
Elapsed Time 0.146 msecs
[color="#FF0000"]ADDED: Now its time to put pcb back to hdd and install it.[/color]
F3 2>U
Spin Up Complete
Elapsed Time 6.864 secs
this part is not necessary, use when firts try fails
F3 2>/
F3 T>F712
Byte:0712: RealTimeUpdatedFlags = 00 00
Byte:0712: Bit:0, HPA_SET_BY_SETMAX = 0
Byte:0712: Bit:1, HPA_SET_BY_SETMAX_EXT = 0
Byte:0712: Bit:2, DCO_SET_ACTIVE = 0
Byte:0712: Bit:3, CONGEN_READ_FROM_MEDIA = 0 <- configuration not loaded from surface
F3 T>F,,22
Drive Configuration restored to defaults.
F3 T>F712
Byte:0712: RealTimeUpdatedFlags = 08 00
Byte:0712: Bit:3, CONGEN_READ_FROM_MEDIA = 1 <- done
(end of part to skip at first attempt)
F3 T>/1
F3 1>N1
F3 1>/
F3 T>m0,2,2,0,0,0,0,22
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 00, Max Certify Rewrite Retries = 0000
User Partition Format 5% complete, Zone 00, Pass 00, LBA 00008DED, ErrCode 00000080, Elapsed Time 0 mins 05 secs
User Partition Format Successful - Elapsed Time 0 mins 05 secs
F3 T>
(finished, power off)
PostPosted: February 12th, 2012, 13:31
PERFECT!!!!!!
I am not an expert, but it is so easy.
THANKS.
PostPosted: October 22nd, 2012, 11:10
welcome.
Users browsing this forum: inflex, Majestic-12 [Bot] and 6 guests
