Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
 Post subject: 5400.5 problem
PostPosted: May 6th, 2009, 5:34
Anybody experienced this :
Drive reads perfectly from sector 0 to 25 xxx xxx (25MIL+) with MHDD scan and others.
Not a single sector after an exact LBA (25 xxx xxx) will read at all.
zone table ? adapatives ?
Seen more than one similar drive with this symptom.
 Post subject: Re: 5400.5 problem
PostPosted: May 6th, 2009, 5:57
I already had some with that problem.
Have you tried to regen translator?
PostPosted: May 6th, 2009, 7:36
First thought goes to translator... agree. Can you read completely and access the SA ?
PostPosted: May 6th, 2009, 9:58
Thanks for reply, translator regen, I don't have anything like pc udma,
but use terminal commands. Yes, SA can be read easily.
Need to know if regen of 5400.x , 7200.11 varies for models, don't want
to do wrong m0,,,,,,,,,,,,, command
PostPosted: May 6th, 2009, 15:27
that's translator problem
somebody tried to recalc it
PostPosted: May 7th, 2009, 2:03
How did you read it ?
Terminal - as the normal way.
PostPosted: May 7th, 2009, 2:06
Thanks Doomer,
not sure if someone else worked on this drive. Will check with the owner.
Be interesting to know what can go wrong with regen (m0)
for 5400.x drives and if commands vary for different drives.
PostPosted: May 7th, 2009, 2:14
Different arch = different command. Careful!
PostPosted: May 7th, 2009, 2:42
Agreed, just applied 7200.11 m0 command to good working 5400.5 and
got the same result.
Different family different command - different command options, and
no help for commands. Who's got this for 5400.5 ??
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewr
ite Retries = 00C8
User Partition Format   0% complete, Zn 00, Pass 00, SoftCnt:0, SoftPBA:0, SoftE
rrCode:0, ZnReWrite:0, ZnReCertify:0, IsRd:0, HardPBA:0
User Partition Format Successful - Elapsed Time 0 mins 00 secs
Total Grown Defects:0 XFatalBlkAddr_PBA:0
PostPosted: May 7th, 2009, 18:18
many things can go wrong
from my experience such "things" happen on all 5400.5, 5400.6 and 7200.3 drives
PostPosted: May 7th, 2009, 18:20
Congratulations
If you didn't backup SA before that will be realy hard to fix the drive back
PostPosted: May 8th, 2009, 0:49
Anyone here who can fix such situation ? - location UK.
PostPosted: May 8th, 2009, 2:42
Owner confirmed original drive was sent to other DR company.
Owner reported that drive was not detecting at all.
So, based on this info if true, 5400.5 has same problem as 7200.11.
Does anyone know if pc3000 has included support for 5400.5 models to do
translator regen?
PostPosted: May 8th, 2009, 3:34
Why don't you contact the other company see what they did to it? Out of interest, was it a large company and where are they based?
PostPosted: May 8th, 2009, 12:51
If he has a SA backup it's not so problematic, if not...it's the realm of data reconstruction.
PostPosted: May 9th, 2009, 3:26
I do appreciate the responses, however my question is
Does pc3000 udma support model 5400.5 ?
I am not expecting anyone to list the commands for 5400.5, these will be found shortly,
but does anyone know the answer to the following question :
thanks
PostPosted: May 9th, 2009, 10:22
derp, if your question is "Can PC3000 UDMA fix this drive?" the answer will be - no
PostPosted: May 9th, 2009, 17:41
Thanks, I thought so. Just have to dig some more.
PostPosted: May 10th, 2009, 6:56
If SA is gone, I think you can only put a fresh Fw and selfscan... At least you have the drive (not the data).
PostPosted: May 10th, 2009, 17:05
Hi BlackST,
Which parts of SA, in your professional opinion, do you know
are modified by incorrectly using m0 for 7200.11 for 5400.5 ?
Are you able to restore 5400.5 drive (with data) as in this case ?
Users browsing this forum: Google [Bot], Rendersmith and 67 guests
