bochen415 wrote:
neowakesup wrote:
Seriously guys, plz share the solution IN the forum...
Here's the fix only for the ST31000528AS 1TB Barracuda 7200.12 Firmware: CC38 model:
ROb wrote:
start your drive by shorting read channels
F3 T>/2
F3 2>Z
Spin Down Complete
Elapsed Time 6.035 secs
[Remove the shorting and give following command]
F3 2>U
HighPowerMode
ExecuteSpinRequest
Spin Up Complete
Elapsed Time 3.573 secs
F3 2>/
F3 T>m0,2,2,,,,,22
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 16, Max Certify Rewr
ite Retries = not supported
User Partition Format Successful - Elapsed Time 0 mins 00 secs
F3 T>/1
F3 1>N1
Clear SMART is completed.
F3 1>
[disconnect the power, wait couple seconds and connect again]
Rst 0x08M
(P) SATA Reset
Now if your drive is working go and copy quick all the data you can and if not throw it out tho the garbage or send it to the manufacturer.
Shorting read channels:short the pins shown here
http://qbhn.neostrada.pl/ST31000528AS.jpg
this is the component side, it goes through the pcb to the other side, I think here
http://qbhn.neostrada.pl/02.jpg
but not sure - thrust the first image its 100% ok
Thanks everyone. I fixed my ST31000528AS 1TB Barracuda 7200.12 Firmware:
CC49 model hdd with help of that and with another command.
At first I have to say my aim for fixing it was to USE it. Not for data recovery but it was surprising when I saw 2. and 3. partitions (with files in them) on my hdd were't deleted after my fix.
I used soldering,may be you don't have to but if you will then it is your own risk.My mobo couldn't see hdd in bios or hot swap. It was after a low voltage and psu failure.
I tried a lot of things but always got an error
Rst 0x20M
Servo Processor Is Reset.
RW: Disc Ctlr Initialization Completed.
ExecuteSpinRequest
(P) SATA Reset
Then I looked at connections on the PCB and measered the diots with a cheap and simple multimeter and found these diodes on SATA DATA connection are not working. I soldered them to disable / by-pass them. After soldering; data flows from SATA port to PCB like there is no diode. Don't solder any diode with another one.
http://img427.yukle.tc/images/3649Clipboard02.jpg
http://img429.yukle.tc/images/5606Clipboard03.jpg
You can see 3 other diodes next to the ones that I marked. They were running OK in my hdd but if not in yours, you can solder them.
Then I tried the commands with the help of a DKU-5 cable. But I got "Inıt SMART fail" errors and I did like that:
[Power your hdd with shorting read channels as R0b and bochen415 says like in that image: http://qbhn.neostrada.pl/02.jpg]
Rst 0x20M
ExecuteSpinRequest
(DOS) Table Read FAIL
DOS: MAGIC CONFIG NUMBER MISMATCH
No HOST FIS-ReadyStatusFlags 2002A185
[Here Ctrl+z]
ASCII Diag mode
F3 T>/2
F3 2>Z
Spin Down Complete
Elapsed Time 10.515 secs
F3 2>U
HighPowerMode
ExecuteSpinRequest
Spin Up Complete
Elapsed Time 6.125 secs
F3 2>/
F3 T>m0,2,2,,,,,22
[If computer or hyperterminal freezes here, disconnect and reconnect both DKU cable(from usb port) and hdd power cable. Then Ctrl+z again.]
F3 T>
ServoDiscSlip Time = 003F13DB
ASCII Diag mode
F3 T>/1
F3 1>N1
F3 1>/
F3 T>i4,1,22
F3 T>m0,2,2,,,,,22
F3 T>
After that I removed DKU-5 cable connections and atteched hdd to computer and restart. It was visible on BIOS and windows saw hdd with all partitions. I tried seagate tools -both windows and dos but couldn't full erase disk to fix bad sectors. I am running hdtune and erasing it, if that won't work, I will learn where bad sectors are with its Error Scan and setup a couple of partitions to use hdd.
good luck.
