Post new topic Reply to topic  [ 316 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16  Next
 Post subject: Re: New version of R-Studio
PostPosted: October 11th, 2018, 17:17
A new build of R-Studio: Several bugfixes, including a fix for "unsupported APFS encryption methods".
Data recovery, backup, protection.
R-Tools Technology, Inc
PostPosted: October 23rd, 2018, 17:05
A new build of R-Studio for Mac: The same bugfixes, including a fix for the "unsupported APFS encryption methods" bug.
PostPosted: December 17th, 2018, 12:06
A new version of R-Studio. New features: estimation of chances for successful file recovery, recovery of names and paths for files deleted to Recycle Bin and Trash, and support for the ReFS 3.4 file system. Improvements: a complete redesign of the Find/Mark dialog box, improved parsing and reconstruction of the FAT32 and NTFS file systems and scanned APFS partitions.
Please note that this is estimation rather than conclusive information on chances for successful file recovery. After file enumeration, it's necessary to run the Recheck Recovery Chances command to get some meaningful information on recovery chances. Scan is required to obtain the best results.
PostPosted: December 17th, 2018, 16:12
Does this take into consideration the DeepSpar map?
RAID Data Recovery
PostPosted: December 19th, 2018, 14:09
No, only R-Studio internal estimations.
PostPosted: December 19th, 2018, 16:18
Dang. I really wish that your team would add it. It seems weird that I can see the files that have bad sectors, but have no way of filtering or sorting based on that information.
RAID Data Recovery
PostPosted: December 20th, 2018, 14:29
We'll do this soon. But no dates promised.
PostPosted: December 20th, 2018, 16:15
That would be awesome. I've been asking for it since the integration with DeepSpar, so a little more time won't hurt.
RAID Data Recovery
PostPosted: January 8th, 2019, 13:13
Hi its a great app, but where we can see size of recovered folders? is it possible? if not please add, thanks.
A Beginner in Data Recovery with MRT Ultra
PostPosted: January 8th, 2019, 14:46
Select the folder and look at the volume that shows on the bottom of the window.
RAID Data Recovery
PostPosted: January 14th, 2019, 11:20
I don't see what you say, maybe you can show me with picture?
PostPosted: January 14th, 2019, 12:22
PostPosted: January 15th, 2019, 12:21
irepair wrote:
Thanks.
PostPosted: February 6th, 2019, 14:01
New versions of R-Studio for Linux and Mac: catching up with their Windows counterpart. New features: estimation of chances for successful file recovery, recovery of names and paths for files deleted to Recycle Bin and Trash, and support for the ReFS 3.4 file system. Improvements: a complete redesign of the Find/Mark dialog box, improved parsing and reconstruction of the FAT32 and NTFS file systems and scanned APFS partitions. Many improvements and bugfixes.
PostPosted: April 22nd, 2019, 16:36
A new version or R-Studio. New features: Get Info panel with detailed file info, NTFS cluster sizes from 128KB to 2MB, duplicate raw files not recovered, improved recovery probability estimation, memory usage optimization, and more. Technician version: extended file information like disk regions, overlapping files, etc, advanced options in file recovery lists like specific file system info, overlapping files, disk regions, etc. Plus many bugfixes.
PostPosted: May 12th, 2019, 15:35
Hello @Alt(R-TT)
i have a issue i am recovered video files many of the apps data is recovered with every software but not playable :(
can you tell me or fix R-Studio to fix this issue ?
waiting for your reply
thank you
PostPosted: May 13th, 2019, 18:20
Most likely not a problem with r-studio ....
Most likely problem with the drive like over-writen data or damaged drive, bad sectors, etc ...
PostPosted: May 16th, 2019, 13:43
same case.
https://forum.hddguru.com/viewtopic.php?f=7&t=38396
PostPosted: May 27th, 2019, 16:26
New versions of R-Studio for Mac and Linux. Keeping up with the Windows version: Get Info panel with detailed file info, NTFS cluster sizes from 128KB to 2MB, duplicate raw files not recovered, improved recovery probability estimation, memory usage optimization, and more. Technician version: extended file information like disk regions, overlapping files, etc, advanced options in file recovery lists like specific file system info, overlapping files, disk regions, etc. Plus a lot of bugfixes. And a new build of R-Studio for Windows: improved LVM processing and many bugfixes.
PostPosted: June 15th, 2019, 3:46
I've 2TB WD hdd which has 6 heads, one head is dead (head 0) so i cloned just those 5 readable surface.
This drive has EXT4 partition, customer needs to recover only few pics, so if he's lucky, i don't have to swap head assembly if i'm able to find residual of logical structure in the partition with a complete scan under R-Studio.
Because R-Studio can't detect the partition instantly due to missing information, i thought that hopefully i would find those pics after many hours of surface scan. Unfortunately it was just about a totally wast of time.
This is what R-Studio shows me after complete scan:
I can recover pics only in RAW, it would be a better recovery if i could rebuild a glimmer of logical structure.
I tried ReclaiMe Pro and it was able to find partially logical structure without scanning all surface, in few minutes :D
