 Post subject: hdd 7200.12 1 tb bsy , after N1 clik clik,mybe head fail?
PostPosted: May 5th, 2011, 2:04
i have hdd 7200.12 1TB fw:cc38 with bsy status
in log terminal
Rst 0x20M
LED:000000CD FAddr:002582FF
standard solotion
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
No HOST FIS-ReadyStatusFlags 2002B001/
Input_Command_Error
F3 T>
ASCII Diag mode
F3 T>/2
F3 2>Z
HighPowerMode
Spin Down Complete
Elapsed Time 0.103 msecs
F3 2>U
HighPowerMode
ExecuteSpinRequest
Spin Up Complete
Elapsed Time 6.358 secs
F3 2>/1
F3 1>N1
after N1 clik,clik
again
F3 2>Z
HighPowerMode
Spin Down Complete
Elapsed Time 0.104 msecs
F3 2>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>/2
F3 2>U
HighPowerMode
ExecuteSpinRequest
Spin Up Complete
Elapsed Time 6.277 secs
F3 2>m0,2,2,,,,,22
Invalid Diag Cmd
F3 2>/t
F3 T>m0,2,2,,,,,22
LED:000000CE FAddr:00258027
and the test head
after command afew second clik clik then
Head 00 Resistance 01E2
Head 01 Resistance 01F8
Head 02 Resistance 01BE
Head 03 Resistance 0196
with worked hdd same model
Head 00 Resistance 013B
Head 01 Resistance 00AA
Head 02 Resistance 00CB
Head 03 Resistance 0125
what's that next step?
1. head swap
2. another solotion
pls help me?
NS DATA RECOVERY
www.nsrecovery.ir
 Post subject: Re: hdd 7200.12 1 tb bsy , after N1 clik clik,mybe head fail?
PostPosted: May 5th, 2011, 12:18
no any ide
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: May 5th, 2011, 12:42
Have you tried to swap heads ?
PostPosted: May 7th, 2011, 1:02
thanks for answer
i try today and post logs
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: May 7th, 2011, 1:32
Can you load App code, CERT code and CERT TABLE code...? Can you run heads test before "tried to swap heads"? Did you think only swap head can help you and more easy than load something and run heads test?
* Có ba thứ ngu dốt :
Không hiểu biết những gì mình đáng biết.
Hiểu biết không rành những gì mình biết.
Hiểu biết những gì mình không cần biết.
PostPosted: May 9th, 2011, 3:46
1. in normal mode hdd bsy and terminal hang
2. in terminal mode
command test head worked also partion info
User Partition
LBAs 00000000-74706DAF
PBAs 00000000-75049101
HdSkew 006E, CylSkew 0038
ZonesPerHd 11
Head 0, PhyCyls 000000-038219, LogCyls 000000-037B4E
Physical Logical Sec Sym Sym Data
Zn Cylinders Cylinders Track Wedge Track Rate
00 000000-004DA8 000000-004DA8 09A0 10FC 00134D00 1593.750
01 004DA9-008B4A 004DA9-008B4A 096C 109F 0012E460 1560.000
02 008B4B-00C08D 008B4B-00C08D 0929 1027 00125E80 1516.875
03 00C08E-010617 00C08E-010617 0900 0FC5 0011F040 1481.250
04 010618-0136C9 010618-0136C9 08B8 0F5D 00117B40 1443.750
05 0136CA-01773A 0136CA-01773A 0870 0ED7 0010E480 1395.000
06 01773B-01C05A 01773B-01C05A 0819 0E45 00104160 1342.500
07 01C05B-01FF2A 01C05B-01FF2A 07E0 0DC9 000FB5E0 1297.500
08 01FF2B-022E9A 01FF2B-022E9A 0798 0D57 000F35A0 1256.250
09 022E9B-0265BA 022E9B-0265BA 0750 0CD1 000E9EE0 1207.500
0A 0265BB-0292BA 0265BB-0292BA 06F0 0C35 000DEF60 1151.250
0B 0292BB-02C3DA 0292BB-02C3DA 06C0 0BC4 000D7040 1110.000
0C 02C3DB-02F82A 02C3DB-02F82A 0654 0B24 000CBC40 1051.875
0D 02F82B-03237A 02F82B-03237A 0600 0A8E 000C1380 997.500
0E 03237B-0352EA 03237B-0352EA 05A0 09CB 000B3700 926.250
0F 0352EB-036EA3 0352EB-036EA3 0580 09AB 000B1420 915.000
10 036EA4-038219 036EA4-037B4E 0558 095E 000ABC60 886.875
Head 1, PhyCyls 000000-03DC81, LogCyls 000000-03D4EA
00 000000-005444 000000-005444 0900 0FC3 0011E980 1479.375
01 005445-009742 005445-009742 08DC 0F9E 0011C100 1466.250
02 009743-00D270 009743-00D270 08B8 0F56 00117000 1440.000
03 00D271-011F89 00D271-011F89 0862 0EC9 0010D280 1389.375
04 011F8A-015586 011F8A-015586 082E 0E6C 001069E0 1355.625
05 015587-019CD2 015587-019CD2 0810 0E38 00103080 1336.875
06 019CD3-01ED90 019CD3-01ED90 0787 0D41 000F1980 1246.875
07 01ED91-0232EB 01ED91-0232EB 0733 0CAB 000E70C0 1192.500
08 0232EC-02674C 0232EC-02674C 06F9 0C43 000DFBC0 1155.000
09 02674D-02A304 02674D-02A304 06A0 0BA3 000D47C0 1096.875
0A 02A305-02D4B4 02A305-02D4B4 0660 0B2D 000CC1E0 1053.750
0B 02D4B5-0309EC 02D4B5-0309EC 0630 0ACF 000C5940 1020.000
0C 0309ED-0343AF 0309ED-0343AF 05E8 0A5F 000BDA20 978.750
0D 0343B0-037382 0343B0-037382 0576 099A 000AFC80 907.500
0E 037383-03A7E3 037383-03A7E3 0524 0909 000A5960 855.000
0F 03A7E4-03C68F 03A7E4-03C68F 0504 08D6 000A2000 836.250
10 03C690-03DC81 03C690-03D4EA 04C8 0861 00099A20 793.125
Head 2, PhyCyls 000000-039AEB, LogCyls 000000-03942B
00 000000-0050F6 000000-0050F6 09D8 1158 0013B5A0 1627.500
01 0050F7-008FEF 0050F7-008FEF 09A0 10FB 00134D00 1593.750
02 008FF0-00C790 008FF0-00C790 0973 10A8 0012EFA0 1563.750
03 00C791-011020 00C791-011020 0930 1035 00126F60 1522.500
04 011021-0142F0 011021-0142F0 0900 0FC4 0011F040 1481.250
05 0142F1-01861F 0142F1-01861F 08A7 0F47 001163A0 1436.250
06 018620-01D0C5 018620-01D0C5 0840 0E8D 00109260 1368.750
07 01D0C6-0210E4 01D0C6-0210E4 07E0 0DC9 000FB5E0 1297.500
08 0210E5-024151 0210E5-024151 0798 0D57 000F35A0 1256.250
09 024152-027997 024152-027997 0750 0CD1 000E9EE0 1207.500
0A 027998-02A787 027998-02A787 06F0 0C35 000DEF60 1151.250
0B 02A788-02D9AD 02A788-02D9AD 06A0 0BA5 000D4D60 1098.750
0C 02D9AE-030F14 02D9AE-030F14 064C 0B15 000CAB60 1046.250
0D 030F15-033B4B 030F15-033B4B 0600 0A8E 000C1380 997.500
0E 033B4C-036ABB 033B4C-036ABB 05A0 09CB 000B3700 926.250
0F 036ABC-03870B 036ABC-03870B 0566 0978 000AD9A0 896.250
10 03870C-039AEB 03870C-03942B 054D 0950 000AAB80 881.250
Head 3, PhyCyls 000000-03F1F4, LogCyls 000000-03EAA4
00 000000-005AE0 000000-005AE0 0A80 1286 00150BA0 1738.125
01 005AE1-00A08C 005AE1-00A08C 0A44 1223 00149D60 1702.500
02 00A08D-00DE18 00A08D-00DE18 09FC 11A7 001411E0 1657.500
03 00DE19-012E37 00DE19-012E37 0990 10D4 00132360 1580.625
04 012E38-016652 012E38-016652 0960 1086 0012CCC0 1552.500
05 016653-01AEFD 016653-01AEFD 0929 1028 00126420 1518.750
06 01AEFE-020141 01AEFE-020141 08B8 0F5E 001180E0 1445.625
07 020142-02469C 020142-02469C 0858 0EBE 0010CCE0 1387.500
08 02469D-027BFA 02469D-027BFA 0800 0E24 00101E80 1331.250
09 027BFB-02B8D8 027BFB-02B8D8 07A6 0D74 000F5880 1267.500
0A 02B8D9-02EA88 02B8D9-02EA88 075D 0CF7 000ECD00 1222.500
0B 02EA89-0320C6 02EA89-0320C6 0700 0C52 000E1240 1162.500
0C 0320C7-035A89 0320C7-035A89 0696 0B9E 000D47C0 1096.875
0D 035A8A-038A5C 035A8A-038A5C 064C 0B18 000CB100 1048.125
0E 038A5D-03BDC0 038A5D-03BDC0 05E0 0A5F 000BDFC0 980.625
0F 03BDC1-03DC6C 03BDC1-03DC6C 05B8 0A0C 000B8260 950.625
10 03DC6D-03F1F4 03DC6D-03EAA4 0570 098C 000AF140 903.750
System Partition
LBAs 00000000-0012D07F
PBAs 00000000-0012ECFF
HdSkew 006E, CylSkew 0018
ZonesPerHd 02
Head 0, PhyCyls 03821A-03836D, LogCyls 000000-000152
00 03821A-0382C3 000000-0000A9 0390 0634 000720C0 588.750
01 0382C4-03836D 0000AA-000152 0390 0634 000720C0 588.750
Head 1, PhyCyls 03DC82-03DDD5, LogCyls 000000-000152
00 03DC82-03DD2B 000000-0000A9 0390 0634 000720C0 588.750
01 03DD2C-03DDD5 0000AA-000152 0390 0634 000720C0 588.750
Head 2, PhyCyls 039AEC-039C3F, LogCyls 000000-000152
00 039AEC-039B95 000000-0000A9 0390 0634 000720C0 588.750
01 039B96-039C3F 0000AA-000152 0390 0634 000720C0 588.750
Head 3, PhyCyls 03F1F5-03F348, LogCyls 000000-000152
00 03F1F5-03F29E 000000-0000A9 0390 0634 000720C0 588.750
01 03F29F-03F348 0000AA-000152 0390 0634 000720C0 588.750
but command m in T> or 1>N1 not worked
and with dr tools salvation data i do'nt have access to sa modules
and below message appear
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: May 9th, 2011, 3:52
I think it could be head problem or a surface problem.. so work carefully on it or the risk is to lose all your files!
Data Recovery pro in Italy (Azienda Italiana Specializzata nel recupero dati)
http://www.italianrecovery.it
PostPosted: May 9th, 2011, 5:59
i swap heads but is not different and same older bsy
and added clik clik
maybe sa main modules error
i test heads again in new condition
heads in main hdd
Head 00 Resistance 013F
Head 01 Resistance 00A9
Head 02 Resistance 00CC
Head 03 Resistance 0129
this is normal
but in this one
heads in donor hdd
Head 00 Resistance 015C
Head 01 Resistance 00C7
Head 02 Resistance 00DC
Head 03 Resistance 0141
?why? :?:
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: May 9th, 2011, 6:49
in log terminal
Rst 0x20M
standard solotion
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
Input_Command_Error
F3 T>
ASCII Diag mode
F3 T>/2
F3 2>Z
HighPowerMode
Spin Down Complete
F3 2>U
HighPowerMode
ExecuteSpinRequest
Spin Up Complete
F3 2>/1
F3 1>N1
after N1 clik,clik
again
F3 2>Z
HighPowerMode
Spin Down Complete
F3 2>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>/2
F3 2>U
HighPowerMode
ExecuteSpinRequest
Spin Up Complete
F3 2>m0,2,2,,,,,22
Invalid Diag Cmd
F3 2>/t
F3 T>m0,2,2,,,,,22
and the test head
1. head swap
2. another solotion
pls help me?
again the same as i replied before 1 min. to another post, power up n listen carefully to the power init. & head sound.
PostPosted: May 27th, 2011, 3:35
:lol:
i solved this problem
now i work for image all hdd 1tb
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: May 27th, 2011, 8:06
Nice work. So what was the solution?
Data Recovery Cape Town
PostPosted: March 14th, 2012, 14:29
yes can you share the solution i've the same error
Users browsing this forum: Google [Bot], Rendersmith and 68 guests
