 Post subject: Seagate Pharoah_oasis st500dm009 error LED:0x000000EE FAddr:
PostPosted: July 2nd, 2018, 8:34
Hemendra
Newbie
Contact: Contact Hemendra
Seagate Pharoah_oasis st500dm009 error LED:0x000000EE FAddr:0x003211FC
#10
Postby Hemendra » Mon Jul 02, 2018 5:01 pm
I have Seagate ST500dm009 Firmware CC43
Family 9401 Pharoad_oasis.
Terminal output
Boot 0x20M
SpinUp
Rst 0x20M Thermistor Temp 001F
Retry delay
Retry delay
DOS:0 Scan Unit
LD:
PP:
pcb no: 100774000 REV C
I can't access terminal. After terminal port it gives immediately LED error.
Noclicking, NO motor stop.
Thanks,
 Post subject: Re: Seagate Pharoah_oasis st500dm009 error LED:0x000000EE FA
PostPosted: July 6th, 2018, 4:25
Attached the PCB Photos.
I have Tried for the marked two points for Terminal Access T>. but can not sucess.
is any option or suggestion?
PostPosted: November 16th, 2018, 7:46
It is pretty though to determine the cause of that error message precisely without having the drive.
People say shorting some pads on pcb sometimes help, but to be honest i never use such trick, usually avoid the error by other means.
No bitcoin donations :)
