 Post subject: Flash Recovery
PostPosted: July 8th, 2018, 11:53
Hey!
After a short discussion on reddit a user kindly forwarded me to this forum.
I crushed my USB stick after a bycicle crash. The chip has a small crack and starts to overheat as soon as I plug it into a USB.
Even if I'm not very confident to recover any data successfully, I'm just getting curious how to perfom a pinout on such a chip. I own a beginner SMD station and just started with SMD in general.
So there are a couple of questions:
1. Is there any specific term for this type of piggyback / monolithic all-in-one device? First, I was pretty sure I just found the USB-Male adapter. Persons on reddit confirmed that this is a kind of all-in-one-design, with the PCB directly on the chip.
2. Considering the overheating issue: Is this an clear indication that the chip is garbage or could it be that "just" the pcb/controller is broken?
3. Considering the process of pinning-out: How do I proceed? Should I remove the USB connector and restore the blank BGA under hot air?
4. I tried to google the specification on the chip; however I had no luck, what are good resources. Are there any other resources to identify the chip?
File comment: Crack
 Post subject: Re: Flash Recovery
PostPosted: July 8th, 2018, 18:25
Oh, the irony!
PostPosted: July 8th, 2018, 22:20
You *could* take it to a professional, but from the picture, it seems it is dead. Or after hearing the price of the recovery, you will decide the chip is dead. :D
PostPosted: July 9th, 2018, 2:50
If chip heats after connection usually it means recovery not possible (internal short or broken crystal inside).
Odzyskiwanie danych
PostPosted: July 9th, 2018, 7:29
+1 agree
PostPosted: July 9th, 2018, 12:04
Well,
Crystal is broken ,Nothing can be done ,This pendrive is EOL "End of Life " .
PostPosted: July 10th, 2018, 20:05
Amarbir[CDR-Labs] wrote:
Nothing can be done
?? Superglue ??
Recover My Flash Drive
PostPosted: July 10th, 2018, 20:09
jeremyb wrote:
?? Superglue ??
Have some feeling for the client pain :(
PostPosted: July 11th, 2018, 0:17
Ouch
These small USB 3.0 UFD's look more like a MicroSD card inside...
PostPosted: July 11th, 2018, 2:20
Speaking of pain, I hope there were no serious personal injuries.
PostPosted: July 13th, 2018, 2:40
Banned User
USB can recognize chip, and you can ask some expertise for advice or look through some related books.
Users browsing this forum: Majestic-12 [Bot] and 5 guests
