 Post subject: Need Hitatchi firmware
PostPosted: July 14th, 2018, 19:23
Trying to track down firmware for the following hitatchi drives:
HUA721010KLA330
HDE721010SLA330
I've done some extensive research to see if I could track down firmware. I did find some potential firmware for HUA721010KLA330, but it's dell firmware and unsure how that will work, if at all. Just for reference for any looking, I found the firmware from the link below:
https://www.dell.com/support/home/us/en ... erid=kd2f4
I'm willing to give that firmware a chance and just JTAG the PCB later if the firmware bricks the drive.
Any hitatchi firmware version will work for my needs, though I prefer newest firmware if possible. They currently have custom firmware on them which locks the drives to only negotiate 1.5gbps link speeds which my HBA won't support.
Thanks!
 Post subject: Re: Need Hitatchi firmware
PostPosted: July 14th, 2018, 21:07
A drive's firmware consists of many modules. Only a few of these modules would be targeted by an update. I suspect that in your case you would be looking at the FEAT (features?) module.
Alternatively, there could be a configuration setting in the NVRAM on the PCB.
You might like to investigate "Niagara":
http://files.hddguru.com/download/Software/HGST/
Edit: You might be able to achieve your ends with Hitachi's Feature Tool:
https://www.hgst.com/support/hard-drive-support/downloads/legacy-downloads
Warning! Switching your drive to support 3.0Gb/s, or enabling spread spectrum clocking and then using it, may render your drive unusable in a system that cannot support these functions. If in doubt, please contact your system manufacturer.
PostPosted: July 14th, 2018, 22:40
I will check out the suggested took asap.
As far as the feature tool, I can't get it to detect my drive. I dont have hardware old enough for it to detect my drive correctly.
Thanks!
PostPosted: July 15th, 2018, 4:57
Online
What is your goal ? To set the SATA speed only ???
For IBM based drives including newer HGST ARM you can set the speed of the SATA link using a vendor specific command...
You don't need to flash anything and i trully doubth that flashing firmware would help you out as the update wouldn't change the drive configuration no matter if it's stored on NVRam or FEAT ...
PostPosted: July 15th, 2018, 11:07
@fzabkar; Checked out Niagara and while I'm pretty sure I found the right section to set link speed, it seems to have failed:
CMD: A1 06 20 54 02 00 C7 A9 00 8F 00 00
     FE SC LL LM LH DH CM
ATA: 54 02 00 C7 A9 00 8F
Error (0 ms) At 08:56:52 07/15/18
<E> Check Condition:
Info: Command Returned 0 bytes
70 00 0B 00 00 00 00 0A 00 00 00 00 00 00 00 00
00 00
Translation: Aborted Command.  No Additional Sense Code.
For reference, after opening Niagara (spti driver detected my drives) I ensured only the target device was selected, then went to ATA Tools > Set Features > Vendor Unique Features > 0x54: Set SATA Speed Limit > 0x2
@Spildit; Primary goal is to set link speed to 3Gb/s. I was finally able to get the drive to show up to the feature tool from hgst, but it claimed the drive didn't support changing link speed.
So as a note, this drive came out of a NetApp appliance and was previously flashed with NetApp's custom firmware. What all that changes, I'm unsure, but that's the main reason for trying to find stock firmware. I'm not sure I can set the link speed until I've gotten rid of this garbage NetApp Firmware.
Thanks!
PostPosted: July 15th, 2018, 11:59
Update! I noticed another feature to "Disable Force Gen 1" for the drive. Executed that successfully on the HDE721010SLA330. I will try it out on some others but that might have been the trick I needed.
I'll also test this on the HUA721010KLA330 when I get home and can swap to the disk.
I'll post some updates later tonight.
Thanks!
PostPosted: July 15th, 2018, 12:57
Online
Looks like Niagara did use some sort of CDB instead of ATA VSC ...
For the record the ATA VSC that i do use to set SATA speed is not the same as the one you did use.
You used a variant of 8F and i use EF with a completly diferent parameter on error/feature.
PostPosted: July 18th, 2018, 15:22
Completely forgot to post an update. Niagara did the trick, same advanced option for both drives to disable force gen 1.
PostPosted: July 18th, 2018, 16:08
Thanks for the feedback.
PostPosted: July 18th, 2018, 18:30
Online
Cool ! Nice that it did work out for you !
PostPosted: November 14th, 2018, 23:01
00 00
Thanks!
Apologies for resurecting such an old dog! But I'm facing an issue with a HGST HTS541010A9E680 http://forum.hddguru.com/viewtopic.php?f=1&t=37692 while trying to restrict the negotiated speed to SATAII, instead of SATAIII. If you have time, please could you come over to that topic or drop me a PM? Many thanks in advance!
Users browsing this forum: No registered users and 0 guests
