 Post subject: stupid question about moving SA to secondary heads
PostPosted: September 13th, 2018, 16:19
Hello, I wish to do something stupid. I know this must have been tried. Please help route me to the correct path my light giving friends and bail me from the dark path.
Some WD HDDs have 4 heads or more. Primarily the SA is written on head 0 and 1.
At times tracks of head 2 (physica, 0,1,2) can be read too and have a different 01 over there. (Was randomly trying to read head 2 of some family drive that i dont remember now and did a tracks to module, DFL found dir mod on this secondary head and tried to generate a few modules from the tracks read just from head 2)
So can i put the working primary SA of such drives onto head 2(physical) and have the ROM fetch 01 from this head?
let me know
If you want me to redraft my question, will happily do that.
 Post subject: Re: stupid question about moving SA to secondary heads
PostPosted: September 16th, 2018, 12:48
So formated SA on 0 and 1 and wrote it by tracks to 2 and 3 heads...
no detection err abrt....
Is it something that one has to instruct in rom to fetch SA from the redundant heads?
if so, can some body help me find it?
PostPosted: September 30th, 2018, 10:26
I did never "play" with this but you can use auto option on WDMarvel to move S/A from the system head ...
If you don't need the data just use SeDiv, WDMarvel, etc to run AUTO ARCO and disable the head(s) that you don't need to use. ARCO will write the firmware and it's copy to another platter surface !
For example you can run AUTO ARCO and disable head 0 and 1. On the process ARCO procedure will write firmware to the next available heads.
PostPosted: September 30th, 2018, 10:27
If you are doing manual "hacking" to move the SA you will need to edit firmware regions on ROM as well so that the drive will load ROM at start and will know where to find the correct locations for firmware ...
PostPosted: October 16th, 2018, 16:38
I shall try it all...thanks for the link
PostPosted: October 16th, 2018, 17:24
Please do let us know if it does work out for you.
PostPosted: October 17th, 2018, 7:39
Yes sir. Hope you have a great day ahead....out of almost 80 college assignments i have completed just 30...totally bambooed :D
Users browsing this forum: No registered users and 0 guests
