 Post subject: Fujitsu doctor and MHT2040AT
PostPosted: December 26th, 2018, 14:53
Given that this particular tool is quite limited, I just attached a fujitsu MHT2040AT, this drive works good actually but through the Sw i can do practically nothing with it. That drive gets ready, passport ok, sector view ok, but module list is empty. It seems an issue for a non-supported drive but it is listed on a manual though so I guess it should be supported. Any clue?
Thanks in advance
 Post subject: Re: Fujitsu doctor and MHT2040AT
PostPosted: December 26th, 2018, 15:14
I expect that it won't work with your model, but you could try this:
Script for retrieving Fujitsu HDD CPs :
http://www.hddoracle.com/viewtopic.php?f=91&t=2163
PostPosted: December 26th, 2018, 15:55
IT WILL WORK JUST FINE !!!
:D
VSCs to READ CPs on Fujitsu are the SAME for all Fujitsu AS LONG AS THE DRIVE IS NOT LOCKED BY ATA PASSWORD.
Even on modern SATA you can read CPs with those VSCs - you will not be able to read the 2 CPs with master and user ATA password but you can read all the rest.
On MHT2040AT you have a IDE 2.5 so you can read ALL CPs and write all CPs as well.
If not please do let us know.
PostPosted: December 26th, 2018, 15:58
Even better get HRT demo : - http://www.hddoracle.com/viewtopic.php?f=30&t=2297
Read here - http://www.hddoracle.com/viewtopic.php?f=56&t=2517
Now you can use the commands here - http://www.hddoracle.com/viewforum.php?f=203
http://www.hddoracle.com/viewtopic.php?f=92&t=57
Enjoy !
Goes without saying be carefully when WRITING CPs ...
PostPosted: December 26th, 2018, 16:35
Thanks for the kind replies back! Actually I'd like to understand why this is not working as it is supposed to. Specifically I don't care about recovering data in this case. Any ideas?
PostPosted: December 26th, 2018, 17:44
What do you want to do ? Dump firmware modules ?
If you haven't already get the HRT DEMO and try the VSCs on my post. If it does work on your drive there are no reason for SD tool not to dump those CPs as well ....
Do yu want me to check with TeamViewer ? Just make sure that you connect the drive to a port that is detected by Victoria for windows (don't plug the drive to SD tool) and i will check if i can dump the modules with HRT DEMO.
PostPosted: December 26th, 2018, 18:42
Actually I was tinkering with that doctor trying to evaluate its functions and limitations. Honestly I expected to encounter much more drawbacks with toshiba drives instead of fujitsu ones. :lol: I was wrong
I'll take a look into what both of you guys suggested (thanks again), but I want to manage better what is going on here with this doctor before going any further.
So someone has a direct experience with this doctor? :)
PostPosted: December 26th, 2018, 19:03
People would say that it's junk and that even pirated PC3K PCI would be better .... :shock: :shock: :shock:
PostPosted: December 26th, 2018, 19:45
Got the point. Anyway I would never support a pirated board, there are people behind these tools, it's just in my personal opinion btw.
Anyway for the sake of learning and sharing to anyone might be interested, I figured out that it was an issue of the software linked to a db (or at least it is what it stated). Mhj mht mhk mhl mhm mhn mho mht, are the families which caught this particular error and in this case i switched to mhr, selected ide, then saved just a couple of modules (got errors with others), lastly switched to mht after that (getting no errors) and able to save the other modules too. Also the other functions seem to work.
The last thing which I still have to figure out is the terminal window that gets no output (baud 19200), enter, ctrl, [, no way to get any output so far
PostPosted: December 26th, 2018, 20:03
Can you post some screen captures of the Fujitsu tool ? What functions does it have ?
Interesting because the VSCs should be the same to read the CPs / modules on all the drives so i can't undersnatnd why you are getting modules when selecting some families and you are not able to retrieve modules when selecting other families ....
Well ....
As for terminal try CTRL + for times or CTRL ^
PostPosted: December 27th, 2018, 7:27
Yes of course i'll do it :)
At the moment just take a look at the fujitsu manual you can grab from here:
https://forum.hddguru.com/viewtopic.php?f=20&t=37821
The latest doctors are much more limited than the other ones btw, yet also that manual is kind of a presentation and without useful informations unfortunately
PostPosted: December 27th, 2018, 15:17
Ok ! I will check that later.
Regards.
Users browsing this forum: Exabot [Bot] and 1 guest
