 Post subject: cloning NVMe express SSD
PostPosted: April 27th, 2019, 9:08
Hi all
I am trying to clone NVMe express SSD on SATA hard disk for logical recovery. I have ordered pci express adapters for the same which are yet to arrive.
Meantime my 6th gen motherboard is having 4 NVMe ports. I am trying to clone SSD but I am unable to access it.
I have tried HDDSUPER clone latest build but it does not detect SSD and program even does not start on this motherboard.
I have tried to enable legacy mode and disable UFEI but in vain.
Can someone pls. suggest any other software? Will PCI express adapter will solve this issue ?
Which is the Best adapter since there are several of them available.
Thanks a lot
 Post subject: Re: cloning NVMe express SSD
PostPosted: April 27th, 2019, 10:46
Probably it will solve it as usually if you have a nvme by default motherboard will either read the nvme first and try to boot it or it will boot other system but wont see the nvme.
Something like this works fine for me.
https://www.amazon.com/SupaHub-Dual-PCI ... B078N7LK61
PostPosted: April 28th, 2019, 10:15
Online
I believe this person also emailed me about this, so I will give an additional reply here.
First, in Linux the NVMe drives don’t show up as the usual normal devices (such as /dev/sda). They show up with the likes of /dev/nvme0. HDDSuperClone defaults to using SCSI/ATA passthrough, which only works with the normal devices. To see the drive in HDDSuperClone would require switching the mode to “Generic block device”, where it should then list the drive as an available source. Listing all block devices can also be done with the lsblk command.
Second, the email indicated they are using the HDDLiveCD, which is built on the older lubuntu 14.04. It may not have the drivers for NVMe. In this case the solution is to use some newer Linux live version (such as lubuntu 18.04), and install/run HDDSuperClone from within that live environment. There are basic instructions in the user manual for how to do that.
I would think that it should be possible to see the NVMe drive in a modern Linux environment using the motherboard.
http://www.sdcomputingservice.com
Home of HDDSuperClone and HDDSuperTool
PostPosted: April 29th, 2019, 23:51
Hi maximus
Thanks for your valuable support.
Yes I emailed you separately because as a developer you are the only one who can find solution using hddsuperclone.
I will try using latest linux version and report.
Thanks again
PostPosted: April 30th, 2019, 8:53
what about windows 10 environment Mr .maximus ?
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: April 30th, 2019, 17:28
Online
When it comes to software only tools, I don't consider windows a good platform for any sort of physical data recovery, other than working with perfectly healthy drives that only need logical recovery. Windows does not play well with any sort of failing drive that has issues. Physical cloning/recovery is best done with Linux. If the drive is perfectly healthy, then I would guess it would be okay, but then you would need to install windows 10 on the computer in question on a separate drive. With Linux you can do many things with a live CD.
PostPosted: April 30th, 2019, 22:35
Hi maximus and friends
Sorry for the mistake. I got more details from engineer who has tried to clone.
As per him program does not start itself on all 6th gen intel motherboards. I thought SSD is not detected but that is not the case. We have all different motherboards but live cd does not start on any 6th gen motherboards. It runs perfectly on older motherboards.
PostPosted: May 1st, 2019, 16:49
Online
Then the second part of my solution still stands. Download some other newer Linux live DVD (such as lubuntu 18.04) and see if that will boot. If it does, then it is possible to install/run HDDSuperClone in that live DVD environment.
PostPosted: May 2nd, 2019, 13:13
Thanks mr maximus
Tawfeek Mokhtar
PostPosted: May 17th, 2019, 4:44
Hello friends .
I have got similar task , I have to only copy data which is present on SSD. I have tried 3-4 pci express cards but all of them ask for drivers.
Unfortunately I am not at all proficient in operating linux . As suggested by maximus I have created lubuntu v18 live cd but I am unable to insall / run hddsuperclone from it.
Has someone created hddsuperclone based on latest version of lubuntu ?Can you pls.share ISO ?
Thank you.
Also if someone could guide which driver to use in windows that will greatly help me.
PostPosted: May 17th, 2019, 19:36
Online
terminator2 wrote:
Hello friends .
Thank you.
There are instructions in the HDDSuperClone user manual for how to use it on a Live CD/DVD. But I will give short basic instructions here for how to do it from a current lubuntu 18.04 live cd.
Download the .deb installer of HDDSuperClone from the website. Make sure to choose the proper version for the live cd, either 32 bit (x86) or 64 bit, depending on which version of the live cd you have. Copy that .deb file to a USB flash drive. Once booted into the live cd, plug in the flash drive, and open it. Double click on the .deb file, and it will prompt to install. Once it is installed, it can be started from the terminal with “sudo hddsuperclone”.
Creating a Live DVD of a newer version of lubuntu (18.04 as of now) is on my to do list, but it is not that easy and so it will be some time before I do have it available.
PostPosted: May 18th, 2019, 3:32
Hi Thanks Maximus
This information will be helpful for me. By this time lubuntu has released version 19.
I will attempt to create live CD. However I will not be able to run it on terminal as I have never worked on terminal before.
Thanks. :good: :-D
Users browsing this forum: Bing [Bot], Google [Bot] and 41 guests
