 Post subject: scsı drives controler card
PostPosted: November 1st, 2019, 3:23
I need help about SCSI drive, I have no experience about SCSI, If you have any experiance can you help me about which controler card, scsı cable and converter I need to buy, My drive model is st3146707lc.
I have tableau t4 scsı bridge but when I connect data cable drive stop spinning I dont anderstand cause of this behavior.
Can you help please. Also I have an adaptec card but I show same behavior when data cable connected.
 Post subject: Re: scsı drives controler card
PostPosted: November 1st, 2019, 5:23
I'm not sure tableau t4 supports 80 pins, but this device is already used for forensic image and should be work. If you're looking for a controller card, I suggest you look at it as HBA (Host Bus Adapter). you can easily find it quickly even in a search. like this (Adaptec 2248700-R U320 PCI Express X1 1-Channel SCSI Host Bus Adapter)
PostPosted: November 1st, 2019, 5:26
I was wondering, was the hdd running smoothly on any server before? Did the error while just receiving the image or clone?
PostPosted: November 1st, 2019, 17:02
Check the Delayed Start and Remote Start configuration settings.
https://www.seagate.com/files/staticfiles/support/disc/manuals/enterprise/cheetah/10K.7/SCSI/100260915d.pdf
cron
