 Post subject: 1.8 samsung micro sata HS12VJF
PostPosted: April 13th, 2010, 11:24
heya all. Anyone worked on these drives? I am curious about possibility of PCB swaps on them small ones if electronic failure is suggeted.
 Post subject: Re: 1.8 samsung micro sata HS12VJF
PostPosted: April 13th, 2010, 11:26
Its possible, but I am sure you will have to do a lot of research on that. :wink:
www.datarecoveryne.com
PostPosted: April 13th, 2010, 11:27
I dont mind spending my time and researching = ) I just hope that the info is on the net =) Smth tells me its not gonna be as easy as just swaping adaptives from a board to board eh =)
PostPosted: April 13th, 2010, 11:30
I wonder if its all BGA on 1.8s...
PostPosted: April 13th, 2010, 11:53
Not only BGA. CSP or similar too. Some parts are sooooooooooooooooo small....
P.S. something tells me that you'll search for a long time.... :D
PostPosted: April 13th, 2010, 11:56
smth tells me i wont find what i am looking for. Very little info on open net.
PostPosted: April 13th, 2010, 13:41
No info on the net. Lookit at PCB it seems the adaptives are on CPU. There is 1 chip TLS2309 that puzzles me. No idea what it is. Other then that its a sad day. Anyone can tell me what this TLS chip is plz ?
PostPosted: April 13th, 2010, 15:02
Combo chip spindle + VCM
PostPosted: April 13th, 2010, 15:07
It looks like a TI spindle and voice coil controller.
Search for "TLS2" at http://www.datasheetarchive.com/
You will see similar parts.
PostPosted: April 13th, 2010, 15:27
ty gents. I apretiate the help.
So i am asuming for a PCB swap to work on this beastie will require moving the CPU. And the TLS can stay behind =)
PostPosted: April 13th, 2010, 15:42
Not only :D
PostPosted: April 13th, 2010, 15:45
damnit =)))
Users browsing this forum: Google [Bot], pepe and 129 guests
