 Post subject: Special case "Cute ring" :-)
PostPosted: April 19th, 2010, 16:15
Hello gurus,
I have a WD scorpio drive with this " ring ", any chance to recover the data ?
The drive can't spin up, I thought it was a "common" head stick.
But I found this. :D
 Post subject: Re: Special case "Cute ring" :-)
PostPosted: April 19th, 2010, 16:18
I can do that, if you are interested.
Janos
PostPosted: April 19th, 2010, 16:58
Difficult but not impossible. Assuming some data is lost for sure.
PostPosted: April 19th, 2010, 21:03
how about others platters condition? 2 platters?
data recovery service[/b]
PostPosted: April 19th, 2010, 22:13
unknown20010 wrote:
Hello gurus,
Well ,
Before You Give Up Try It ,Remeber There is Something Called Reverse Cloning As a Hint To you
PostPosted: April 20th, 2010, 3:04
Thanks for your responses gurus,
Thank you Mr.Janos for trying to help, but the case has been closed and the customer refused to recover his data because I told him : that will cost you more than a new drive : 1200 L.E = Approx 200 USD.And he shouted : I can buy 4 new drives with this amount.Then I said : OK, go ahead. :mrgreen:
The FDB motor wasn't even try to spin up because of this "ring", and the heads couldn't move from it's parking area too.
I know Mr.BlackST it's a difficult issue, and I prepared myself to work on it. But the customer was F**kin idiot. :)
1 platter and 2 heads.
Amarbir wrote:
Well ,
Thank you Mr.Amarbir for your hint. :)
Thank you all for your responses.
I appreciate your help.
Users browsing this forum: Google [Bot], pepe and 133 guests
