 Post subject: How to Recovery file system of AIX V4 operating system
PostPosted: April 27th, 2010, 0:35
hi all,
I haf a drive with the copy of a AIX file system, this copy is of a raid 5. I need read the data but i dont know a software for recovery aix V4 of a ibm server risc.
Thanks For Your Help....
 Post subject: Re: How to Recovery file system of AIX V4 operating system
PostPosted: April 27th, 2010, 14:22
It certainly would help if you could provide some more info on this. If I remember AIX 4 uses JFS1. There are some software solutions that can handle JFS. However JFS1 is not the same as JFS for Linux. And if you have a RAID set then it certainly would make things even more fun :D
Depending on what the problem is, using another AIX box to mount the FS would be a possible option. If that does not work, send it to a pro. If you are a pro, then outsource to a shop that has experience with AIX.
Users browsing this forum: Google [Bot], pepe and 120 guests
