 Post subject: ST3250823AS Problem
PostPosted: May 27th, 2010, 13:51
Hello, i have a strange problem with this Barracuda 7200.8. My mb bios can`t see this hdd on ahci mode. what can i do? And its there any tool to reinstall the firmware for this one? Current firmware is 3.03. Thank you
 Post subject: Re: ST3250823AS Problem
PostPosted: May 27th, 2010, 15:52
The firmware is not an issue on 7200.8 drives. First of all you need to identify problem. See if drive spins up, check if it makes sounds.
PostPosted: May 27th, 2010, 17:50
Yes it spins and it doesn't make any strange sounds/clicks. i had w7 installed on this hdd if i set my md bios in ide mode the bios see the drive but in ahci mode it just freeze while scanning for drives. my other 3 drives (a seagate 1tb another seagate 300 gb and a WD 160 GB) works fine only this one has problems.
PostPosted: May 27th, 2010, 18:06
To start u diagnostic´s u need soft wich works by ATA commands ,check if reach readiness, if its fully identified " Model, SN, Capacity, " and check answer´s to read sector commands (20h) checking ATA register´s statud and control answer " IDNF; UNC; ABRT; AMNF ERR, DRDY DSC BSY, DRQ " etc while its reading sector , on deep u can get terminal logs to identified problems over seagate , dont ask me how to did that , search it u will get some answer´s
Users browsing this forum: Google [Bot], Majestic-12 [Bot], napalm_atx and 103 guests
