 Post subject: WD 160 BEVS
PostPosted: May 26th, 2010, 17:03
Hi to all,
Have this disk that the heads "Sliders" get stuck in the platte H1 H2 H3
As i can show in pictures.
This one i mark with a color red.
I Could Get the H2 H3 out but the H2 stays there.
Any ideya how can i get that "slider" out.
ZeBong
" Россия еще раз"
 Post subject: Re: WD 160 BEVS
PostPosted: May 27th, 2010, 6:10
I think you recieved the drive from another company tried to free the heads already and failed, am I right ?
PostPosted: May 27th, 2010, 6:20
no the drive was close not open.
When i try to free the heads they where really stuck in the platte. :)
I am change heads now, and get the data.
ZeBong
" Россия еще раз"
PostPosted: May 27th, 2010, 6:22
Good job :good:
And good luck when retrieving the data too :)
PostPosted: May 27th, 2010, 7:06
I also just received such a WD1600BEVS. Same observation. Same problem. Client said was dropped while powered on. In my case only slider of H3 was lifted and stuck to platter.
http://pcrecoveryllc.com
PostPosted: May 27th, 2010, 7:33
I've seen this exact same situation after a "percussive maintenance" on a wd1600bevs with probable head stiction....
PostPosted: May 27th, 2010, 19:51
do you think it will work for this kind of case? :)
data recovery service[/b]
Users browsing this forum: Google [Bot], Majestic-12 [Bot], napalm_atx and 92 guests
