 Post subject: MX740-6 , SS stops ...
PostPosted: June 17th, 2010, 17:28
Scenario :
Maxtor MX740-6L, SS starts correctly (modules are not broken in this case as if you start it "as is" ends after start : "Selfscan Premium Pass" and quick flash ... very nice :D )
The error occurs after PES, WPC, airlock, Bode, resonance, something else that I don't remember and some optimization :
SSEC=00AC , FWEC =0000
any idea about who is the culprit or anybody had similar experience?
Note : at this point disk is almost tuned, but would be nice to make it end regularly :S
Note #2 : if not comfortable on open forum, PM as always.
Thanks.
 Post subject: Re: MX740-6 , SS stops ...
PostPosted: June 19th, 2010, 7:18
Thanks D. ,
What makes it strange is the fact that it happens at the same place on many drives, all that happens is spspdchk , spindown and this error (led flashing at 1 sec. interval) . NOTE : cycling power resume SS but not from this point, it restarts - maybe something is not updated in logs or.... ?!?
Error lists are still not filled when this happens (cleaned them before starting). Drive is fully operational if you erase LBA with pattern and work fine (for what I can see). Checking servo and scanning surface then push into P would take a lot of time , this is why I want the drive to make it autonomously...
Any other idea ?
PostPosted: June 21st, 2010, 2:32
It happens like this in these drives but user area is OK at this point so the work is done my friend .
PostPosted: June 21st, 2010, 8:33
Starting thinking so, but I am stubborn. The problem is isolated now, only need to make everything work - servo check is painfully slow!
PostPosted: June 22nd, 2010, 7:27
I have much to learn I think.... :?
PostPosted: June 22nd, 2010, 9:31
Everyone has... never give up !
Users browsing this forum: fouad19764, Google [Bot] and 169 guests
