 Post subject: Peltier cooler pads
PostPosted: June 23rd, 2010, 9:52
Heya all. Some hard drives like to be imaged in a bit cooler enviroment. Some drives just run crazy hot. Now as an idea , does anyone using peltier cooling pads or smth like it to help image the drives?
 Post subject: Re: Peltier cooler pads
PostPosted: June 23rd, 2010, 12:06
Hi, nope but I sometimes use a regular 80mm or 120.. systemfan...workes for me :mrgreen:
Bosse
http://www.rescue-it.se
PostPosted: June 23rd, 2010, 12:21
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0500004606
Databusters Data Recovery Glasgow
http://www.datarecovery.co.uk/latest-data-recovery-jobs/
PostPosted: June 23rd, 2010, 18:21
You may want to live next to a nuclear power station and bring your wellies.
1. Pelters consume massive amounts of power.
2. pelters perform spot cooling , a fan can provide air swap and all round cooling.
3. if a Peltier gets too cold, then say hello Mr frosty, with possible ice and frost on drive. (think winter time usage)
4. fans make a noise when they run and come with RPM sensors in a good one, so you know when it is working.
5. Pelters are VERY dependent on the ambient temp and temperature differential between the sides.
6. Pelters fail silently.
7. A Peltier needs a massive heat sink and forced cooling system (wow a fan to cool the Peltier, and a Peltier to cool the disk drive)
8. if the Peltier fan fails/stops or the heat sink thermal barrier is breached, where does all the heat from the current dumping Peltier go?
Universal Declaration of Human Rights: Article 19
PostPosted: June 24th, 2010, 9:27
No to a peltier yes to a fan i see =) Ty all for input.
Users browsing this forum: Google [Bot] and 205 guests
