 Post subject: ROM for WD1200JB-00DUA3 need
PostPosted: July 14th, 2010, 6:20
I need ROM for this drive:
MDL: WD1200JB-00DUA3
FW: 75.13B75
ROM: 75.71
Damon
 Post subject: Re: ROM for WD1200JB-00DUA3 need
PostPosted: July 14th, 2010, 7:03
does this work with u?
let me know
PostPosted: July 14th, 2010, 7:38
Unfortunately not. On Your screenshot are firmwares from different models of WD.
I need one exactly matching firmware and ROM version.
Anyone has it?
PostPosted: July 14th, 2010, 8:12
sorry i only have this
PostPosted: July 18th, 2010, 16:37
Nobody really has this ROM in database? :(
Please check...
PostPosted: July 18th, 2010, 19:44
here you go.
ROM.rar [112.37 KiB]
Downloaded 275 times
data recovery service[/b]
PostPosted: July 27th, 2010, 9:51
Thank you very much networkpc3000!
But I have to change problem in this topic.
I asked of new ROM for that drive because I was sure that ROM is corrupted. After starting WD utlility in PC3K there was error at Zone Allocation table (RAM section of ROM). This error was even when I boot up PCB in kernel mode, so no reading from HDA. I put on my PCB ROM given to me by networkpc3000 and I have the same problem. It cannot be PCB, because I put different ROM version on this PCB from the same MDL drive and that one is ok.
My question is: what's going on with this case or maybe I'm unlucky enough that copy from networkpc3000 is also bad?
Comparing my original ROM and the one from here - they are identical :cry:
Damon
Users browsing this forum: No registered users and 181 guests
