 Post subject: hdd autodetect failed, real died?
PostPosted: August 13th, 2010, 4:41
Because my HDD is over 10 years (IBM 850MB HDD) and not good to store, I think platters data loss?
PCM error? platter error?
I check that POWER cable and IDE cable insert CDROM, can detect.
next step, reversal that device, insert HDD. not detect.
I used support IDE33/66 motherboard.
channel A
IDE0 = HDD, was verify Master
IDE1 = null
channel B
IDE2 = CDROM, was verify Master
IDE3 = null
First BIOS set autodetect IDE channel A,B, but no detect A. only detect CDROM.
and BOOT FROM CD (Used Windows 98 OS)
After BOOT, drive code C: not found.
In this case, how to handle...
real died?
 Post subject: Re: hdd autodetect failed, real died?
PostPosted: August 13th, 2010, 9:34
Check if ur HDD spins. If it spins - check if it makes any sounds.
Users browsing this forum: Google [Bot] and 183 guests
