 Post subject: HDD WD 200 doesn't start
PostPosted: August 13th, 2010, 7:11
Hello.
I have a problem with my WD 200EB. Then i connect my HDD to pc Disk management found's it but could not initialize. I tried to do something with MHDD, and it says Drive not ready.
Here are some pics.
http://img843.imageshack.us/i/errorch.jpg/
http://img185.imageshack.us/i/error2r.jpg/
Is it a problem with hardware or software?
 Post subject: Re: HDD WD 200 doesn't start
PostPosted: August 13th, 2010, 10:51
If you look at the MHDD screenshot, specifically the status register, it looks like you have wrong channel selected, or disk is not connected at all.
If there are jumpers on the unit remove and try again in MHDD.
There are some common issues with these older disks, if you cannot verify the problem safely yourself get it analysed by a professional.
PostPosted: August 13th, 2010, 11:14
DID you do SHIFT+F3 in hdd and select you HDD. plug into secondary master ide. and disconnect any other hdd's to avoid wrong info.
Free Solutions
PostPosted: August 13th, 2010, 11:31
Alternatively, try Victoria from within Windows. Should give same result.
Users browsing this forum: Thedatarecoverylab and 159 guests
