 Post subject: hitachi hds721616pla380 component
PostPosted: August 3rd, 2010, 17:29
hi there, just wondering if this component is replaceable? the drive went pop with smoke and this is the only part i can find at fault.
If i were able to get on, and If i were able to solder it on could the drive work again?
what is the part called and where can they be bought from?
below is a picture of the part i need, it has WE 66 A on it.
thanks for any help.
jake
 Post subject: Re: hitachi hds721616pla380 component
PostPosted: August 4th, 2010, 4:08
Its called a TVS.
Do some search about TVS on this forum and you'll quickly understand how to solve (if nothing else is damaged).
Dobre
Murphy was an optimist
PostPosted: August 4th, 2010, 5:10
On the other hand, Q3 legs seems unsoldered and what the hell happened with the power connector?
www.datasave.ro
PostPosted: August 7th, 2010, 16:28
hi there, thank you for the replies, sorry its taken me a while to get back on here.
pics not too brill, but ive looked at Q3 and it is still soldered on
ah yes, ahem. i had to carefully hack that bit off for it to fit into a usb sata enclosure which i used once then sold.
good work there guys, ill research the TVS.
cheers
jake
PostPosted: August 7th, 2010, 16:35
thank you for the replies guys,
i'll look into the TVS thing
i checked q3, the pic want too good but it is still soldered
ah yea, ahem, i had to hack a chunk of plastic off to get the drive to mate up to a sata enclosure i had a while ago. didnt damage anything tho :D
cheers guys
jake
PostPosted: August 17th, 2010, 9:56
The WE marking code is used by Vishay / General Semiconductor for a bidirectional 5V TVS diode, p/n SMAJ5.0CA.
Normally these diodes are unidirectional.
Even more confusing, the same marking is used by Vishay / General Semiconductor for an SMZG(J)3791A 12V zener diode.
If you can upload a photo of the whole corner of the PCB, I believe that will confirm that it is a 5V diode.
PostPosted: August 18th, 2010, 4:45
jake
I am starting to feel that the bad diode is the least of your problems... :?
Users browsing this forum: Thedatarecoverylab and 161 guests
