 Post subject: wd2500jb-22gvco HDD failed- HELP
PostPosted: September 5th, 2010, 15:03
Hello Everybody,
I'm very new to Forum's, and not sure of the etiqet (sorry).
Can someone please help me? my WD2500JB has failed.
On board chip U1 burnt out. How can I retrieve data on HDD to another HDD.
If card replacement needed, any idea where I can get one from, and how much?
Drive details are:
MDL: wd2500jb-22gvco
date: 8 May 2005
DCM: HSBACVJAH
Details on PCB:
2060-701265-001 REV A
Sticky label says: 2061-701265-200AH
Many Thanks,
Papasmurf :(
 Post subject: Re: wd2500jb-22gvco HDD failed- HELP
PostPosted: September 5th, 2010, 22:41
When replacing the board, you may need to transplant the 8-pin serial EEPROM chip at U12 from patient to donor. If you don't feel comfortable doing this yourself, your local TV/AV repairer should be able to do it for you.
PostPosted: September 5th, 2010, 23:30
Hi fzabkar,
If I get another card which is a direct replacement (same ref nos), does u12 still need replacing?
Will I damage the new card if I try it first without changing u12?
Many Thanks,
Simon.
PostPosted: September 6th, 2010, 3:08
I'm not a DR guy, but my understanding is that, if the adaptives are not closely matched, the drive will click, but there is no risk of damage to the card, or its firmware.
Good luck anyway.
PostPosted: September 6th, 2010, 8:09
Yes there is instead. The drive at startup updates some part in service area and in some case , as adaptives are different, writes badly. Then you have to fix the SA too later. Want to try ?
PostPosted: September 6th, 2010, 11:01
HI GUys,
I think I'll buy a new PCB and swap U12 to new card., then try it.
Hopefully that will sort it.
Found a card/drive on the web for approx $50.00 So might get that soon.
From http://www.hdd-parts.comor http://www.donordrives.com
Thanks for your assistance.
:) :beer:
PostPosted: September 6th, 2010, 16:59
Please let us know if those vendors are reliable.
Good luck.
PostPosted: September 6th, 2010, 18:51
If u wanna go for sure, also check preamp
see also this
Users browsing this forum: szlaci_s70, unknown and 145 guests
