 Post subject: WD10EAV-S00D7B1 PCB - F/W or heads?
PostPosted: February 24th, 2009, 5:47
Hi Everyone.
WD10EAV-S00D7B1
06 NOV 2008
HHNNNT2MAB
Drive above powers - clicks softly 6 times - motor stutters (slows slightly for maybe 0.5 seconds) - clicks 2 times - motor stutters - clicks 2 times - motor stutters - clicks six times. and then repeat...
6 click
motor slow
2 click
motor slow
2 click
motor slow
6 click
I have swapped PCB with a working drive but i suspect F/W incompatibilty as it will not scan on MHDD with the donor PCB board on (0 LBA). But i think this family (kermit??) is not supported by PC3K and there is no ROM that i can swap to force compatibility.
Any ideas please? Thanks in advance
 Post subject: Re: WD10EAV-S00D7B1 PCB - F/W or heads?
PostPosted: February 24th, 2009, 5:59
what happens with the 'bad' drive pcb on the good donor drive?
I'm sure there is rom on this drive, just not the conventional 8 leg chip. Is this a Royl drive?
PostPosted: February 24th, 2009, 6:06
Hi Spaz,
Client drive + donor PCB = 0 LBA does not ID
Donor Drive + Client PCB = 0 LBA does not ID
CLient Drive + CLient PCB = clicking
I think it is kermit family (where do they get their names? :roll: ) if it is royl though then will PC3K support it. Or I have Seagate Dr as well. I could try that i suppose.
thanks
EDIT - HD Dr. for seagate won't work because it is a Western DIgital drive...yes i realise that now 8) lol
PostPosted: February 24th, 2009, 6:13
Please add PCB number...
Mikippp
PostPosted: February 24th, 2009, 6:17
PCB No. =
2061-701590-A00 05P
XC 7C12 92RZ Q 0006190
9196
I think it is the top one you mean?^^ But i wrote them all just in case.
PostPosted: February 24th, 2009, 6:25
PCB: 2060-701590-000 REV A -> Atlantis (probably)
Can U read ROM in PSV (kernel) mode from patient and from donor...
Mikippp
PostPosted: February 24th, 2009, 6:34
buffbagwell wrote:
Hi Spaz,
Than this is not head problem, but more likely some SA problem. :S
Whit this combination the drive doesn't clicking?
Spins up and try to read the SA?
Janos
PostPosted: February 24th, 2009, 7:06
In new WD Royl it is not possible to work with SA if ATA Ovl. is not loaded!
Mikippp
PostPosted: February 24th, 2009, 7:47
Thanks for everyones suggestions. I will try later today.
PostPosted: February 24th, 2009, 7:51
what happens after hot swap?
PostPosted: February 24th, 2009, 7:57
I do not think Hot Swap is possible on ROYL drives because of adaptive information? Also the 'D7' in model number seems to suggest kermit family, not atlantis.
Can ROM be read in similar utility in PSV mode?
PostPosted: February 24th, 2009, 9:47
WD10EAVS
Yet Caviar Green
Mikippp
PostPosted: February 24th, 2009, 10:08
Great! :?
From the pdf:
StableTrac™ — The motor shaft is secured at both ends to reduce system-induced vibration
and stabilize platters for accurate tracking during read and write operations. (2 TB model only)
WD only can this way stabilize the eccentricity issue, if i think right. :S
Now we need another alignment practice on the top lid! :?
Fortunately only on the 2TB drives at the moment....
Janos
PostPosted: February 24th, 2009, 10:10
Mikippp
Is there a way to load the needed Ovl without the good working HDA?
Janos
PostPosted: September 20th, 2010, 13:39
I just wanted to add that I have a WD250JB pulled from a MyBook that has very similar symptoms.
It clicks
Spins up, clicks 6 times spins down
Spins up, clicks 2 times spins down
Nothing.
Very similar, but I don't get that 4th spin up with 6 clicks like you do.
BTW, did you get any luck?
new orleans computer repair
PostPosted: September 20th, 2010, 14:05
I think you will find that your drive (probably REA) is not relevant to this (1.5+ year old) discussion of ROYL drives
PostPosted: September 20th, 2010, 14:11
Yeah =) I was reading from the top was surprised to learn that Kermit is not supported =)) then i saw the date
Users browsing this forum: szlaci_s70, unknown and 151 guests
