 Post subject: wd5000bmvv probable PCB failure
PostPosted: September 21st, 2010, 15:52
I had a break in recently and my backup drives were stolen. I do however have a dead WD Passport that should have most of my work still in it. So I'm hoping someone here can give me some advice. When the drive stopped working it did not make any clicks or odd noises, it just stopped spinning up and stopped mounting. I checked on my linux machine and dmesg does not show any communication with the drive when I plug it in. The drive itself lights up when I plug it in, and then begins flashing. The usb controller on this drive is integrated into the main pcb, consequently I don't have the option of trying it internally or w/ a new enclosure. Repairing this drive is beyond my skill level, but maybe someone here could recommend a pro. The data is valuable but I'm not exactly wealthy.
Thanks!
 Post subject: Re: wd5000bmvv probable PCB failure
PostPosted: September 21st, 2010, 16:04
Absolutely not at your level, but there's always a reputable pro from this forum in your area (unless you don't mind sending the drive abroad so the range / choice is much broader). Where are you exactly if possible to say it in public ?
PostPosted: September 21st, 2010, 16:32
I'm in Durango, Colorado, USA. I am not opposed to sending the drive out, quite the opposite. I just want to find a person or business who definitely has the skill and equipment to attempt this recovery.
PostPosted: September 21st, 2010, 17:07
Here's a photo of the circuit board. I don't see anything burnt, but I do notice a discolored spot that might be the culprit. Hope this is of use.
PostPosted: September 21st, 2010, 18:39
There are many reputable members of this forum throughout the USA , who first maybe can pm you, or you can use the search forum function then get in contact, or companies like i365 . In EU : me and many others. If in a reasonable time you don't find/get a contact , just ask.
PostPosted: September 21st, 2010, 19:46
i can handle it with reasonable price. it can be use same model of USB-PCB or same type of SATA PCB for replace. please feel free to contact me by email or MSN if still need help.
data recovery service[/b]
PostPosted: September 21st, 2010, 21:54
Hey Sunny boy, are you in the US of A? or Made in China?
PostPosted: September 21st, 2010, 22:33
hi,
i come from China. :)
Users browsing this forum: unknown and 145 guests
