 Post subject: WDC disconnected / reconnected in a second itself
PostPosted: September 12th, 2010, 21:43
I have 2 of 1 tb WDD (SATA WDC WD10 SCSI Disk Device) , the one on physical drive 2 looks healthy on winxp disk storage management, but for a week it is from time to time disconnected / reconnected in a second itself. scandisk gives no error.
Everest home report :
--------[ Windows Storage ]---------------------------------------------------------------------------------------------
[ SATA WDC WD10 SCSI Disk Device ]
Device Properties:
Driver Description SATA WDC WD10 SCSI Disk Device
Driver Date 7/1/2001
Driver Version 5.1.2535.0
Driver Provider Microsoft
INF File disk.inf
Device Properties:
INF File disk.inf
[ Intel(R) ICH9 Family 2 port Serial ATA Storage Controller 2 - 2926 ]
Device Properties:
Driver Description Intel(R) ICH9 Family 2 port Serial ATA Storage Controller 2 - 2926
Driver Date 9/25/2007
Driver Version 8.3.0.1016
Driver Provider Intel
INF File oem2.inf
Device Resources:
IRQ 19
Port E700-E707
Port E800-E803
Port E900-E907
Port EA00-EA03
Port EB00-EB0F
Port EC00-EC0F
[ Intel(R) ICH9R/DO/DH 4 port Serial ATA Storage Controller 1 - 2920 ]
Device Properties:
Driver Description Intel(R) ICH9R/DO/DH 4 port Serial ATA Storage Controller 1 - 2920
INF File oem2.inf
Device Resources:
Port F000-F00F
Port FC00-FC0F
[ Primary IDE Channel ]
Device Properties:
Driver Description Primary IDE Channel
Driver Version 5.1.2600.5512
INF File mshdc.inf
Device Resources:
IRQ 14
Port 01F0-01F7
Port 03F6-03F6
Device Properties:
INF File mshdc.inf
[ Secondary IDE Channel ]
Device Properties:
Driver Description Secondary IDE Channel
INF File mshdc.inf
Device Resources:
IRQ 15
Port 0170-0177
Port 0376-0376
Device Properties:
INF File mshdc.inf
[ GIGABYTE GBB36X Controller ]
Device Properties:
Driver Description GIGABYTE GBB36X Controller
Driver Date 9/29/2007
Driver Version 1.17.28.0
Driver Provider JMicron Technology Corp.
INF File oem7.inf
Device Resources:
IRQ 16
Memory FC000000-FC001FFF
Port B000-B007
Port B400-B40F
Port BCF0-BCF3
Port BCF4-BCF7
Port BCF8-BCFF
Please help.
Thanks.
Jamil Sinan
http://www.alkhutt.net/
 Post subject: Re: WDC disconnected / reconnected in a second itself
PostPosted: September 13th, 2010, 2:14
I would check wiring and power, especially if the two drives are on the same wiring rail or adapters/multiple adapters are used. This comes to mind 1st.
PostPosted: September 13th, 2010, 17:21
I will second what BlackST said
Try an different power cable connection, I would even swap out the sata cable too.
If none of this works get all the data off that drive you can and RMA it back to WD.
PostPosted: September 25th, 2010, 0:05
Hi.
First of all thanks to everybody here.
I found where is problem : Gigabyte MB needed drivers updates.
Finally I d/led updates, after installation things things went fine.
Thanks again. :mrgreen:
Jamil Sinan
Users browsing this forum: unknown and 127 guests
