 Post subject: Deskstar™ 7K1000.C PCB swap
PostPosted: September 27th, 2010, 6:47
I have received a few drives of the latest Hitachi HDD's Deskstar™ 7K1000.C
Several with burnt PCB and one with mechanical problem. I intended to use the good PCB as a replacement for one burnt. For my surprise I couldn't find a NVRAM chip on the PCB, only a 2MBit Flash. With or without Flash chip swap HDD does not spin up with a donor PCB.
Any suggestions what should be done to solve the problem?
 Post subject: Re: Deskstar™ 7K1000.C PCB swap
PostPosted: September 27th, 2010, 8:43
Let me guess, first you are tried just swap work PCB, later you swap flash and tried again ?
Angel Data Recovery
PostPosted: September 28th, 2010, 4:10
correct
Users browsing this forum: Google [Bot], pepe and 125 guests
