 Post subject: Samsung problems
PostPosted: March 6th, 2008, 16:08
Hello, hdd gurus´s
This is alberto, asking for u help, now arrived Samsung SP0411N 40GB nOT knock, even motor start on, and u can heard the typical recalibration sound on samsung, but its BSY, , on terminal shows the
ENG> SRV> BD thats OK but after some seconds begin´s to show
LED 56 0000 all the time but this is not on samsung manual , does anyone know what does it meaning, ? i tried to exchange pcb, and not solve problem, after exchanged PCB, the typical sound, recalibration, motor stop inmediatly casued by mismatching ROM information and SA information, then LED 5B 0000
Any one know some
Best Regards
 Post subject: Re: Samsung problems
PostPosted: March 6th, 2008, 21:43
Try Soft reset, if it becomes ready after that - enter utility and check modules.
PostPosted: March 6th, 2008, 23:48
Hello starling
i tried ,but not answering,
PostPosted: March 7th, 2008, 16:15
Online
try pcb with other FW version, it should halt on ovly mismatch and u should be able to check sa surface after a soft reset.
PostPosted: March 9th, 2008, 9:43
I have many hdd with pcb mismatch can i repair those hdd with H/T test , matching the P/N like 0611 .
PostPosted: March 9th, 2008, 13:49
Now i can read SA and tracks, doing a HS, even i can get sector LBA 0 but on another´s sectors show AMNF, and on the last cylinder, the same im think this is because need to write Primary Defect List on Donnor ,regenerate translator then did the HS, i will keep u informated
Sinceraly
Alberto
PostPosted: March 11th, 2008, 14:04
Probably you are doing with wrong ROM PCB.
1 it could be ROM fault on original Hard Disk
2 Try with another PCB with Same (main) IC.
All the Best
DF :)
DF :)
www.datatracksystem.net
PostPosted: March 11th, 2008, 23:27
Hello friends
After did HS can get SA modules then i wrote translator modules , and defect list modules modules on donnor and did again the HS :recalibration OK, i can get the LBA 0, ont he sector edit i can see the MBR CODE "33 C0.... partition table 80 01 .... and the boot signature 55 AA. but when i tried to get another, its not possible, show error , even on the end of tracks, on the first , middle etc, DF i tried exchanging the PCB without exchange ROM , and the result its LED 5B , im thinkin on did the platter swap well on this case one head , its the best im think
Thanks for all u comments
Sinceraly from Mexico
Alberto
SA STRUCTURE
SA parameters
Zone #.................................. : 0
Initial cylinder........................ : 0
Final cylinder.......................... : 23
SPT..................................... : 928
ZONE TABLE
Number of zones......................... : 24
# : Head : Initial cylinder : Final cylinder : SPT
1 : 0 : 24 : 3 000 : 1 073
2 : 0 : 3 001 : 6 000 : 1 073
3 : 0 : 6 001 : 8 500 : 1 073
4 : 0 : 8 501 : 12 200 : 1 060
5 : 0 : 12 201 : 17 200 : 1 044
6 : 0 : 17 201 : 21 800 : 1 020
7 : 0 : 21 801 : 26 000 : 1 005
8 : 0 : 26 001 : 29 200 : 991
9 : 0 : 29 201 : 33 000 : 974
10 : 0 : 33 001 : 36 800 : 957
11 : 0 : 36 801 : 40 800 : 928
12 : 0 : 40 801 : 44 900 : 928
13 : 0 : 44 901 : 48 000 : 899
14 : 0 : 48 001 : 51 800 : 881
15 : 0 : 51 801 : 56 800 : 850
16 : 0 : 56 801 : 59 800 : 828
17 : 0 : 59 801 : 63 200 : 812
18 : 0 : 63 201 : 66 200 : 783
19 : 0 : 66 201 : 69 700 : 754
20 : 0 : 69 701 : 73 400 : 725
21 : 0 : 73 401 : 79 300 : 696
22 : 0 : 79 301 : 82 200 : 653
23 : 0 : 82 201 : 85 300 : 626
24 : 0 : 85 301 : 88 800 : 592
MODULES TABLE
Module : Cyl : Head : Sec : Length : Read : CrLev : Real Header : Standard Hdr :
00 FSI : 0 : 0 : 1 : 1 : OK : : FSI : FSI
02 FIT : 0 : 0 : 2 : 4 : OK : D : FIT : FIT
04 MLIST : 0 : 0 : 6 : 1 : OK : As : MLIST : MLIST
05 SRVTBL : 0 : 0 : 7 : 4 : OK : : SV_TBL : SV_TBL
64 SKTIME3 : 0 : 0 : 11 : 1 : OK : : SEEKTIME : SEEKTIME
61 MODELID : 0 : 0 : 20 : 1 : OK : : :
06 CONFIG : 1 : 0 : 1 : 2 : OK : As : CONFIG : CONFIG
07 SNTBL : 1 : 0 : 3 : 2 : OK : : :
08 BISPT : 1 : 0 : 5 : 4 : OK : Dr : END : END
09 BRSLT : 1 : 0 : 10 : 1 : OK : Dr : :
0A CRITERIA : 1 : 0 : 11 : 1 : OK : : : CRITERIA
0B FINALTST : 1 : 0 : 12 : 8 : OK : : :
0C ARCOTBL : 1 : 0 : 30 : 8 : OK : : CHN_TBL : CHN_TBL
0D GEO_TBL : 1 : 0 : 46 : 32 : OK : : :
0E VLISTHDR : 1 : 0 : 78 : 1 : OK : As : VLIST_H : VLIST_H
0F VLIST : 1 : 0 : 79 : 16 : OK : Ad : :
10 SLISTHDR : 1 : 0 : 111 : 1 : OK : As : SLIST_H : SLIST_H
11 SLIST : 1 : 0 : 112 : 128 : OK : Ad : :
12 TLIST : 1 : 0 : 368 : 4 : OK : Ad : TLIST : TLIST
13 ALIST : 1 : 0 : 372 : 8 : OK : Ad : RLIST : RLIST
15 SETMAX : 1 : 0 : 381 : 1 : OK : : : SETMAX
16 SECURITY : 1 : 0 : 382 : 1 : OK : C : : SECURITY
17 SRVTBL2 : 1 : 0 : 383 : 4 : OK : : SV_TBL2 : SV_TBL2
18 ARCOTBL2 : 1 : 0 : 387 : 8 : OK : : CHN_TB2 : CHN_TB2
14 TMPRTR : 1 : 0 : 395 : 2 : OK : : TMPRTURE : TMPRTURE
19 OVERLAY : 1 : 0 : 401 : 396 : OK : Bs : OMLV0Y10 : OMLV0Y10
5A VL40CODE : 2 : 0 : 1 : 600 : OK : Dr : :
5B VL40CHN : 2 : 0 : 602 : 1 : OK : Dr : : VL40_CHN
29 DLIST : 3 : 0 : 1 : 650 : OK : Dd : DLIST : DLIST
41 SPESB0 : 3 : 0 : 701 : 2 : OK : : : SPES
42 SPESB1 : 3 : 0 : 703 : 2 : OK : : : SPES
43 SPESB2 : 3 : 0 : 705 : 2 : OK : : : SPES
44 SPESB3 : 3 : 0 : 707 : 2 : OK : : : SPES
45 SPESB4 : 3 : 0 : 709 : 12 : OK : : : SPES
1A HDAF_RPT : 4 : 0 : 1 : 1 : OK : : :
1B HD_DLIST : 4 : 0 : 2 : 2 : OK : : :
1C LATCHFRC : 4 : 0 : 4 : 1 : OK : : LATCH_FC : LATCH_FC
1D RCOSCRPT : 4 : 0 : 5 : 50 : OK : : RCOSCPT : RCOSCPT
1F ERRTRK : 4 : 0 : 56 : 1 : OK : : : BER
20 ERRZN : 4 : 0 : 57 : 1 : OK : : BER1 : BER1
21 ERRDRV : 4 : 0 : 58 : 1 : OK : : BER2 : BER2
22 SRTDATA : 4 : 0 : 59 : 1 : OK : : ER_CNT : ER_CNT
23 SRTSRVO : 4 : 0 : 60 : 1 : OK : : SV_ERCNT : SV_ERCNT
24 SCN_GRAY : 4 : 0 : 61 : 1 : OK : : :
25 PARAM : 4 : 0 : 62 : 10 : OK : : :
26 WKHEAD : 4 : 0 : 72 : 10 : OK : : WK_HEAD : WK_HEAD
27 TSTPI : 4 : 0 : 82 : 4 : OK : : TPI_WRW : TPI_WRW
28 MRTUNEMT : 4 : 0 : 86 : 5 : OK : As : MR_TUNE : MR_TUNE
1E BTIME : 4 : 0 : 91 : 2 : OK : : BI_TIME : BI_TIME
53 MRRTABLE : 4 : 0 : 93 : 1 : OK : : MRR_TBL : MRR_TBL
54 NPV_RSLT : 4 : 0 : 94 : 30 : OK : : :
56 ARCOTBL3 : 4 : 0 : 131 : 8 : OK : : CHN_TB3 : CHN_TB3
62 BPITEST : 4 : 0 : 141 : 1 : OK : : BPI_TEST : BPI_TEST
63 ARCOTBL4 : 4 : 0 : 142 : 8 : OK : : : CHN_TB4
2A GEO_00 : 4 : 0 : 347 : 112 : OK : : ! UϘ : EG_O00
2B TST_ZH : 4 : 0 : 431 : 64 : OK : : :
2C GEO_ZH : 4 : 0 : 495 : 16 : OK : : :
47 CAPSEL : 4 : 0 : 511 : 1 : OK : : : CAP_SEL
48 CURBPI : 4 : 0 : 512 : 1 : OK : : : CUR_BPI
49 AZLCSM : 4 : 0 : 513 : 1 : OK : : : AZL_CSM
4A AZL_CSM0 : 4 : 0 : 514 : 1 : OK : : : AZL_CSM0
4B AZL_CSM1 : 4 : 0 : 515 : 1 : OK : : : AZL_CSM1
4C AZL_CSM2 : 4 : 0 : 516 : 1 : OK : : : AZL_CSM2
4D AZL_CSM3 : 4 : 0 : 517 : 1 : OK : : : AZL_CSM3
4E AZL_CSM4 : 4 : 0 : 518 : 1 : OK : : : AZL_CSM4
4F AZL_CSM5 : 4 : 0 : 519 : 1 : OK : : : AZL_CSM5
50 AZL_CSM6 : 4 : 0 : 520 : 1 : OK : : : AZL_CSM6
2D AZLBPI : 4 : 0 : 521 : 1 : OK : : : AZL_BPI
2E AZL_BPI0 : 4 : 0 : 522 : 1 : OK : : : AZL_BPI0
2F AZL_BPI1 : 4 : 0 : 523 : 1 : OK : : : AZL_BPI1
30 AZL_BPI2 : 4 : 0 : 524 : 1 : OK : : : AZL_BPI2
31 AZL_BPI3 : 4 : 0 : 525 : 1 : OK : : : AZL_BPI3
32 AZL_BPI4 : 4 : 0 : 526 : 1 : OK : : : AZL_BPI4
33 AZL_BPI5 : 4 : 0 : 527 : 1 : OK : : : AZL_BPI5
34 AZL_BPI6 : 4 : 0 : 528 : 1 : OK : : : AZL_BPI6
52 INSTABHD : 4 : 0 : 533 : 4 : OK : : WIIT : INST
57 ATE : 4 : 0 : 537 : 1 : OK : : HEAD_P : ATETST
58 WII : 4 : 0 : 538 : 4 : OK : : SPSTW_ : WIITST
59 TPTP : 4 : 0 : 542 : 1 : OK : : : HEAD_PR
51 SPSTW : 4 : 0 : 543 : 1 : OK : : : SPSTW_DA
36 RCO_LOG : 5 : 0 : 1 : 928 : OK : : : RCODATA
5C TSTPI2 : 7 : 0 : 1 : 4 : OK : : : TPI_WRW
5D BPITEST2 : 7 : 0 : 5 : 1 : OK : : : BPI_TEST
5E ATE2 : 7 : 0 : 6 : 1 : OK : : : ATETST
5F TPTP2 : 7 : 0 : 7 : 1 : OK : : : HEAD_PR
60 BRSLT2 : 7 : 0 : 8 : 1 : OK : : :
66 BER2 : 7 : 0 : 11 : 1 : OK : : :
37 SMART : 11 : 0 : 1 : 9 : OK : : SMARTMEM : SMARTMEM
38 SMRT_LOG : 11 : 0 : 3 : 4 : OK : : :
39 SMRT_TST : 11 : 0 : 10 : 5 : OK : : :
3A SMRT_HLG : 11 : 0 : 15 : 512 : OK : : :
3B BIAS_SHK : 11 : 0 : 527 : 402 : OK : : :
3C HD_ERLOG : 12 : 0 : 1 : 928 : OK : : :
3D ELOG : 12 : 0 : 1 : 928 : OK : Dr : :
46 BIMODAL : 15 : 0 : 1 : 928 : OK : : :
3F SV_TRACE : 20 : 0 : 1 : 3 : Err : : :
40 PES_LOG : 20 : 0 : 11 : 4 : Err : : : SPES
3E IPC_DBG : 20 : 0 : 302 : 1 : Err : : :
65 PMP : 20 : 0 : 304 : 1 : OK : : :
HDD SECURITY SUBSYSTEM
MASTER password......................... :
USER password........................... :
Master Code............................. : 0000
USER password is set.................... : No
Security level.......................... : High
S-LIST - ALLOCATION DEFECTS BY ZONES
: Zone : Head 0 :
: 1 : 14 :
: 2 : 62 :
: 3 : 30 :
: 4 : 51 :
: 5 : 161 :
: 6 : 98 :
: 7 : 42 :
: 8 : 25 :
: 9 : 44 :
: 10 : 13 :
: 11 : 1 :
: 12 : 28 :
: 13 : 32 :
: 14 : 1 :
: 15 : 58 :
: 16 : 10 :
: 17 : 2 :
: 18 : 8 :
: 19 : 19 :
: 20 : 145 :
: 21 : 50 :
: 22 : 33 :
: 23 : 41 :
: 24 : 1 :
: Total : 969 :
T-LIST - DEFECT TRACKS LIST
: # : Zone : Head : Cyl :
: 1 : 1 : 0 : 69 :
: 2 : 4 : 0 : 9471 :
: 3 : 4 : 0 : 11698 :
: 4 : 5 : 0 : 14652 :
: 5 : 6 : 0 : 18788 :
: 6 : 6 : 0 : 21200 :
: 7 : 13 : 0 : 45539 :
: 8 : 14 : 0 : 51409 :
: 9 : 16 : 0 : 57369 :
: 10 : 16 : 0 : 57477 :
: 11 : 16 : 0 : 57478 :
: 12 : 16 : 0 : 57479 :
: 13 : 17 : 0 : 60145 :
: 14 : 18 : 0 : 65849 :
: 15 : 22 : 0 : 80700 :
: 16 : 22 : 0 : 81433 :
: 17 : 22 : 0 : 81543 :
: 18 : 23 : 0 : 82358 :
: 19 : 23 : 0 : 83205 :
: 20 : 23 : 0 : 84536 :
A-LIST - REASSIGN SECTORS LIST
: # : Cyl : Head : Sector -> Cyl : Head : Sector :
D-LIST - ALLOCATION DEFECTS BY ZONES
: Zone : Head 0 :
: 1 : 13 :
: 2 : 62 :
: 3 : 30 :
: 4 : 49 :
: 5 : 160 :
: 6 : 96 :
: 7 : 42 :
: 8 : 25 :
: 9 : 44 :
: 10 : 13 :
: 11 : 1 :
: 12 : 28 :
: 13 : 31 :
: 14 : 0 :
: 15 : 58 :
: 16 : 6 :
: 17 : 1 :
: 18 : 7 :
: 19 : 19 :
: 20 : 145 :
: 21 : 50 :
: 22 : 30 :
: 23 : 38 :
: 24 : 1 :
: Total : 949 :
PostPosted: March 12th, 2008, 3:32
Did u checked the ROM of orginal Hard disk and the Rom of HS hard disk.
DF :)
DF :)
PostPosted: March 12th, 2008, 19:51
Hello friends
Now unsoldered the ROM and soldered on Donnor PCB, after that start on , and reach DRDY DSC, when i tried to did the image, lost the readiness, turn off and turn on again, and on terminal stay showing
LED 56 :(
Im going to check the platter surface from the another side, to check if are scratch or some like this
Best Regards, and thanks for all u help!!
PostPosted: March 13th, 2008, 23:42
Hello friends
Good news, now Get data back from this case ,all 100 of data % :D Thanks GOD.
Thanks for all u help
Alberto
PostPosted: March 14th, 2008, 3:39
Hi,Nice, well done :good:
What was the problem, and how did you fixed it?
Regards/ Bosse
http://www.rescue-it.se
PostPosted: October 5th, 2010, 11:37
hey beto dude i tried to contact you via PM for some help, i was refferred to you due to the fact that we live in the same country, i m sorry i know u make money out of this in town (who doesnt) but i was still wondering if you could still help me out?
a "no" would do just fine,
(sorry for the harsh, is just really annoying to recieved nothing back from a PM, specially if the PM comes from someone asking for legit help, IMO)
thanks.
Users browsing this forum: Google [Bot], pepe and 112 guests
