 Post subject: Seagate ST3500630AS-can be or not repaired
PostPosted: October 10th, 2010, 12:23
When starting out a repeated clank
I have access to the firmware I managed to make a image, after he starting LBA 63
After the first 10 Gb hard disk that can no longer get regular Clank.
Question would be if they can fix it? or the customer will be content with the data
Any advice is welcome.
Terminal log:
CE Log ErrCode=43 LBA=37a66462 Type=5 Add To Pending 37a66462
AT Er 00 Nwt Er 43 RdWr 1ca9d.01.0004
ATA St 50 Er 00 Op ec a,0000/0/00,00 00 00
Niwot: 9ff79ff7 b8 9ff79ff7.3.642 0000 005f 0000 0000
$$SFI
AMR
$$SFI
AMR
DiskAccess ReadSector EC=43 at 01ca9d.01.0004
 Post subject: Re: Seagate ST3500630AS-can be or not repaired
PostPosted: October 10th, 2010, 17:33
repair the drive is not worth, buy a new one.
if you need the data you will need expensive tools for that.
ZeBong
" Россия еще раз"
PostPosted: October 11th, 2010, 1:59
I have make an image using Data Compass
I am interested if it can be repaired or not using PC3K-UDMA-original version
I have not a great experience in this area, I'am beginner
Thanks!
Users browsing this forum: Google [Bot], pepe and 139 guests
