 Post subject: Data Recovery & Specific Filetypes issue
PostPosted: October 11th, 2010, 10:34
Guys,
i have a strange case here which i wanted to share with you,,
I got SCSI HDD, formatted by stupid guy, and the OS is Sco Unix (for some Specific purpose) and application, again i dono the app. name but its for the oil sector issue.
the problem is the following:
I`ve been asked to get the deleted/formatted files from the HDD which has the following extensions:
.rdr
.xtf
.aff
I did the following:
Used, R-Studio 5.1 and made an Image of the Drive (70GB) i tried the Winhex to see those files with the mentioned extension and did manage to find alot.
the Problem:
R-Studio is so stupid, but it is good, it has built-in filetypes i.e. DOC,XLS whatever, but it does not include those mentioned types, i was reading about those issues and managed to know that you can use Customized XML where you can assign those types, but i did not get it yet.
- Is there any way to extract those files from the HDD Image?
Or
- How do i extract those files only from the Disk Image i created?
any clues/help here plz
thnx
Attached: sample files which i got from them to get the file header/id
sample_rdr_xtf_aff.rar [216.29 KiB]
Downloaded 311 times
 Post subject: Re: Data Recovery & Specific Filetypes issue
PostPosted: October 11th, 2010, 10:41
OR:
How do i force the R-Studio to look for those Extensions only??
PostPosted: October 11th, 2010, 11:25
Forget R-studio.
Use WinHex:
-Tools - Disk Tools- File Recovery byType..
Click Signatures
It will open txt file with well-known signatures.
Integrate yours (find some uniq header , save its offset) .
Angel Data Recovery
PostPosted: October 11th, 2010, 11:32
.aff (for this instance only) version 3
BEGIN - 41 46 46 20 52 65 76 2E 20 58 2E 63 - OFFSET 0X38
END - ? More samples :D
waiting for more samples
Free Solutions
PostPosted: October 11th, 2010, 12:22
DR-Kiev wrote:
Forget R-studio.
Use WinHex:
Click Signatures
many thnx for the tip working on it
mean while, am trying to use the D.E. and see in both cases
thnx again :wink:
thnx man for this,,,, working on it
PostPosted: October 11th, 2010, 12:34
END - 00 00 00 30 00 00 00 00
The Signature seems the same on all file from OFFset 0- but offset 0x38 Identifies it as AFF
00000000 00 01 00 00 00 00 00 00 00 00 00 30 00 00 00 00
00000010 00 65 00 00 00 00 00 30 00 00 00 D0 00 00 00 00
00000020 00 01 00 00 00 00 09 78 00 00 00 30 00 00 00 00
00000030 00 00 00 00 00 00 00 00 41 46 46 20 52 65 76 2E
00000040 20 58 2E 36 00 00 00 00 00 00 00 00 00 00 00 00
Checking the other ones now. Will make you a winhex/rstudio file.
Free Solutions
PostPosted: October 11th, 2010, 12:44
.rdr (no idea- some real time text data about pumps and then some encoded data near the end)
BEGINNING- 00 00 00 00 00 00 00 88 6B 31 31 33 62 -OFFSET 0X00
END - 00 00 00 00 00 00 00 00 00 10 00 00 00 0C 58 54 00 00 00
after the end signature there is always another 7bytes of data ? that is always different- I am not sure if this could make the file unreadable by the software?
{ 11 32 B4 00 00 00 00 } ; {08 5B B0 00 00 00 00 } , etc... Not text- just some values.
Free Solutions
many thnx ppumkin for ur time here also reading/working/replying
PostPosted: October 11th, 2010, 19:33
Ok- I see why you were struggling. I tried to do a few tests in R-Studio and it never found anything. Even i tried a simple file and it did not work. I must be doing something wrong. I read the manual over and over and over... i dont understand what the problem can be
I used HexEdit like suggested by DR-Kiev - Finds them straight away using the same GREP syntax. I must be typing something incorrect on the Rstudio
Put this into the WinhexDirectory and try to scan. I tested it on a formatted media- and it finds the signatures ok. But i dont know how well it will work on crowded data.
You can edit the file in excel and see the signatures.
oil-File-Signatures.zip [296 Bytes]
Downloaded 301 times
Free Solutions
PostPosted: October 12th, 2010, 3:08
thnx man for your help/time i did managed to get them, i sent my client some samples to try and confirm which i hope will work with him.
It did work in Winhex and i will inform you with the updates
many thnx man really
PostPosted: October 13th, 2010, 10:51
I Would like to 1st. Thank the following:
DR-Kiev ppumkin
for their time/help and also Tips
more goes really to ppumkin because of the work on Winhex and DR-Kiev for the quick reply
I also wanted to Thank AceLab Technical Support Specially Mr. Roustam for his time and work on this case, i did manage with the help of Acelab TS to find a solution on this case and get the Client Files
Many Thnx really to all of you
:wink: :idea:
Users browsing this forum: Google [Bot], pepe and 125 guests
