 Post subject: Log terminal error
PostPosted: October 20th, 2010, 9:19
Reset
4096k x 16 DRAM
GALAXY - 1_Disk S-6B 08-30-06_15:36
HM SFI
(P)PATA Reset
Master
AT Er 00 Nwt Er 43 RdWr 0eced.00.0000
ATA St 50 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot: 97f29ff7 b6 97f29ff7.1.840 0000 005f 0000 0000
DiskAccess ReadSector EC=43 at 00eced.00.0000
CE Log ErrCode=43 LBA=f2210fd Type=5 Add To Pending f2210fd
AT Er 00 Nwt Er 43 RdWr 0eced.00.0001
Niwot: 9ff79ff7 b6 9ff79ff7.1.840 0000 005f 0000 0000
CE Log ErrCode=43 LBA=f2210fe Type=4 Remove from Pending f2210fe
AT Er 00 Nwt Er 43 RdWr 0eced.00.0002
DiskAccess ReadSector EC=43 at 00eced.00.0002
CE Log ErrCode=43 LBA=f2210ff Type=5 Add To Pending f2210ff
AT Er 00 Nwt Er 43 RdWr 0eced.00.0006
DiskAccess ReadSector EC=43 at 00eced.00.0006
CE Log ErrCode=43 LBA=f221103 Type=5 Add To Pending f221103
AT Er 00 Nwt Er 43 RdWr 0eced.00.000c
DiskAccess ReadSector EC=43 at 00eced.00.000c
CE Log ErrCode=43 LBA=f221109 Type=5 Add To Pending f221109
AT Er 00 Nwt Er 43 RdWr 0eced.00.000f
DiskAccess ReadSector EC=43 at 00eced.00.000f
CE Log ErrCode=43 LBA=f22110c Type=5 Add To Pending f22110c
AT Er 00 Nwt Er 47 RdWr 0eced.00.0014
DiskAccess ReadSector EC=43 at 00eced.00.0014
I look folders and files not copy!! (DE UDMA)
Sorry, copy files?
Thanks! :mrgreen:
Нет ничего невозможного
 Post subject: Re: Log terminal error
PostPosted: October 20th, 2010, 9:49
In pages 18, 19 (11.2.4.11) MANUAL PC3K is help,
Not enough help ...
:shock:
PostPosted: October 20th, 2010, 12:46
Not enough help ...
:shock:
by the data extractor is very very slow but the copy!
Does anyone here have any solution to make this copy be faster?
:mrgreen:
PostPosted: October 20th, 2010, 12:56
Are you using loader in DE to "fix pending bug"?
PostPosted: October 20th, 2010, 13:04
No loader, only UTILITY HDD + DATA EXTRACTOR
PostPosted: October 20th, 2010, 15:54
Do you know how to create a loader from your bad drive? Should not be a difficult case, you have already been given a solution...
Users browsing this forum: fouad19764, Google [Bot] and 151 guests
