 Post subject: Need Help. Logical Drive disppeared, replaced with scanner.
PostPosted: October 14th, 2010, 14:20
I have a curious problem. I have T30 running XP service pack 2. My D: drive is a logical drive, i.e., a partition on the hard disk.
I was scanning a multi-page document via Acrobat, using a WIA-HP ScanJet 5300C, USB scanner, when I was distracted and left the scanning half way through for some time. When I returned, the scanning dialogue had disappeared, with the pages already scanned showing in the Acrobat window. There was some message (presumably an error) showing on the screen, but I accidentally clicked off on it, before I read it. Anyway, I picked up with the scanning where I had left off, and the whole scan completed successfully.
However, when I went to save the file, which had been created, to the D: drive, there was no D: drive listed in the 'save' dialogue. I then tried to open a different file, but again, there was no D: drive in the 'open' dialogue.
I subsequently went to My Computer, and there, where the D: drive should have been in the window, was the scanner, and indeed, clicking on it, took me to the scanner interface. There was also an E: drive missing, which had always previously shown, but that drive is for another OS on the dual boot system.
Both D: and E: drives show up as healthy under Computer Management. From a command prompt, I can get up a DIR of D: and all sub-directories. D: is basically data, but also some programs. I can execute a program on D: from the command line, and I can load and save documents by entering the full path in the appropriate dialogue. I can't search from the graphical interface, because it does not show D:
Using RegEdit, I have restored the registry values to a point just before this happened, but to no avail.
Can someone please tell me how to fix this.
Thanks in advance-
 Post subject: Re: Need Help. Logical Drive disppeared, replaced with scanner.
PostPosted: October 15th, 2010, 23:06
Can you see the D: drive in the GUI if you go to Start -> Run and type ...
explorer D:\
PostPosted: October 16th, 2010, 2:27
From my little experience , if data is important ,Reverse clone disk to cover up D & E drives , you may be able to exploere drives as it is at least you can recover data or repair MBR.
PostPosted: October 16th, 2010, 3:48
explorer D:\
Yes, that brings up a GUI with the content of the drive. Yet, if I just go to My Computer, it doesn't show the drive as existing at all. Similarly, no 'save as' or 'open' dialogue shows the drive at all.
PostPosted: October 16th, 2010, 3:52
This is not the problem. As I wrote in the beginning, the data is there, and can be accessed from the command line.
PostPosted: October 16th, 2010, 4:36
Perhaps the D: and E: drives are hidden.
You can use Microsoft's TweakUI PowerToy to hide and unhide your drives:
http://www.microsoft.com/windowsxp/down ... rtoys.mspx
PostPosted: October 16th, 2010, 5:17
Have already tried that. It doesn't help.
PostPosted: October 16th, 2010, 19:45
How about http://www.intowindows.com/hide-hard-disk-drives-using-windows-registry/
PostPosted: October 17th, 2010, 4:08
icon wrote:
I can confirm that TweakUI modifies the same registry key.
PostPosted: October 17th, 2010, 4:14
explorer D:\
If you type ...
D:\
... in the "Save" or "Open" File Name box, does your D: drive then appear?
BTW, have you considered reposting your question to a Microsoft Windows XP newsgroup?
PostPosted: October 17th, 2010, 10:35
Check in your system if in the Group Policy Editor, Hide drive is enabled
I did not check if that tweak modifies the same registry key mentioned. But I will add this to the mix:
Run gpedit.msc
Go to:
- User Configuration
- Administrative Templates
- Windows Components
- Windows Explorer
- Hide these specified drives in My Computer
Good luck!
PostPosted: October 18th, 2010, 11:17
Run gpedit.msc
Go to:
- Windows Explorer
Good luck!
Brilliant! Thank you so much. All the items under windows explorer showed 'Not configured', but anyway I set the 'hide the drives' item to 'disabled' and all my drive icons are back again.
Once again, many thanks!
PostPosted: October 18th, 2010, 12:44
Good to know it helped! :D
Regards.
PostPosted: October 23rd, 2010, 3:58
mdarwish,
Thanks for your solution, when my drive recognition disappeared - you will recall that in the 'My Computer' the scanner appeared where the drive icon should have been - bit I have only now just realised that my scanner has disappeared from the system. The computer doesn't recognise any scanner being there. Do you have any ideas on this one?
Thanks in advance
PostPosted: October 23rd, 2010, 4:07
You may have driver conflict. I suggest you uninstall your scanner, update your system to SP3, as I see from your first post that you have SP2, and get the latest driver for your scanner.
PostPosted: October 23rd, 2010, 4:27
I know that this may sound crazy, but remove the battery from your
computer for 5 minutes, then reinstall it. Then check your scanner.
If that doesn't work, then it will most probably be a driver.
That's the main battery, not the cmos battery.
Users browsing this forum: fouad19764, Google [Bot] and 156 guests
